taller tranny - Page 5 - Fuelly Forums
Old 07-05-2006, 09:25 PM   #41
Some more thinking out loud... (have a highway trip coming up in the next couple of weeks, which gets me thinking about aerodynamics and gear ratios)
Old 07-05-2006, 09:30 PM   #42
Indeed, you should be fine, my jump was even bigger (I forget the gearing on the auto right now) but it's not even an issue. I think you'll love it,
Old 07-05-2006, 09:44 PM   #43
So I'm kind of "gaining" another gear. The stock tranny 5th gear/diff product is actually slightly shorter than the product of the 4-cyl tranny's 4th gear/diff.
Old 07-06-2006, 05:15 AM   #44
Moderator
GasSavers_DaX's Avatar
Just do the swap already.
Old 07-06-2006, 11:43 AM   #45
Tell you what - I'll go pick up the transaxle from Ivan's garage tomorrow. Maybe I'll do it this weekend. I have all the research done & bases covered.
Old 07-06-2006, 11:49 AM   #46
Matt Timion's Avatar
YAY! Maybe we'll be working on our transmissions at the same time.
I still need to fix my axle seal.
Old 07-06-2006, 12:20 PM   #47
I figure the timing is pretty good for this weekend. Project ForkenSwift is on hold for a week while Ivan works on his driveway (paving stones). Might as well check something else off my list while waiting to resume that...
Old 07-06-2006, 12:24 PM   #48
95metro's Avatar
my OEM odo/speedo will go wonky if I do the swap
Are you sure? The cluster in my Aunt's Metro is identical to mine (with the exception of the trip meter). I assumed the gear on the speedo cable was just a different size to allow the same cluster to be used regardless of engine/transmission...???
But of course I could be very wrong.
95metro is offline   Reply With Quote
Old 07-08-2006, 10:56 AM   #49
I deleted the word "motivation" from the thread title. Started working on the swap this morning.
Old 07-09-2006, 09:19 AM   #50
Lunch time break. So far, only 2 minor snags.
Thank Uncle Sam for high gas prices bear15 Automotive News, Articles and Products 9 08-15-2007 08:43 AM
LPG conversion SVOboy General Fuel Topics 4 03-24-2007 10:33 PM
Auto to Manual Reverse Light Question SVOboy General Fuel Topics 9 03-15-2007 10:28 PM
Free flow exhaust GasSavers_Kraig General Fuel Topics 9 08-07-2006 08:53 AM
