Synthetic vs. Regular Oil - Page 2 - Fuelly Forums
Old 07-29-2008, 02:26 AM   #11
Originally Posted by cmhj2000 View Post
I've been working with synthetics for about 25 years. From my personal experience and a fleet I managed for 5 years the gains varied from 1.5-8% depending on winter/summer and/or short trip versus highway driving.
Bottom line is yes, synthetics can give some added mileage.
Per extended drains? Absolutely, no question. The length will vary on the type of oil used, the type of driving done and to some extent the vehicle.
Most of my personal equipment gets an oil change once a year which is on average about 10K miles and I also use a synthetic based filter versus the cheaper or OEM filter when possible.
Will synthetics save you money? In my case it does.
One thing too about synthetics is we simply use less oil & fewer filters to clog the landfills where recycling filters isn't available.
It can depend on the mileage and type of driving you do. This should be handled on a case by case basis. To many variables are involved to make a blanket statement.
Was rushed for time last night & I should add something.
During my years of fleet maintenance it was found the biggest mileage gains, thru oil useage was in changing all the drive line fluids to synthetic.
In every case where we changed all the drive line fluids to synthetic gains were realized. The biggest gains were seen in the winter, which common sense should suggest as well when doing a proper flush to synthetics in both the trany and final drive for units that had both.
We also used synthetic grease on wheel bearings that weren't sealed and synthetic oil in hubs that required oil baths.
This fall I'll be flushing the trany on our 5 speed Kia Optima 07 vintage W/I-4 that has been averaging 38 MPG at 65 MPH on the Interstate during fair weather. Should be interesting to see what this does. I doubt if the gains will be dramatic since most of the miles logged are on the highway but other benefits will be obtained with the change over.
Do it right the first time with Amsoil! https://autos.groups.yahoo.com/group/Lubricators-r-us/
cmhj2000 is offline   Reply With Quote
Old 07-29-2008, 08:04 AM   #12
I've never used synthetic, but have always used regular 10w40 of various brands changing it at 3K-4K intervals. Over the life of the '88 Escort with 477,000+ miles I would say I have changed brands 5 or 6 times so I don't think there is much difference in conventional oils.
Hipermiler
#47 on my way to #1
Old 07-29-2008, 08:32 AM   #13
yeee gads - that's about 120-160 oil changes . . . lets see if you ran Synlube you would have changed it 4 times.
Now at 17868 miles on Synlube and still running great with one oil change.
Old 07-29-2008, 11:25 AM   #14
You're going to leave the same oil in for 100,000 miles? Not me!
Hipermiler
#47 on my way to #1
Old 07-29-2008, 11:31 AM   #15
I think most believers change their filter on a regular basis and replace however much oil came out with the filter.
Old 07-29-2008, 11:36 AM   #16
I've also heard of people doing this with conventional motor oil, but I never had the nerve to try it.
Hipermiler
#47 on my way to #1
Old 07-29-2008, 11:58 AM   #17
I've heard of the opposite... Changing the filter with every other oil change. I'd never do it though.
Old 07-29-2008, 06:06 PM   #18
Originally Posted by gork57 View Post
JB, how in the world do you get 21 mpg out of a Cadillac Eldorado? Just curious.
I obtained slightly over 20 in my 89 Cadillac Eldorado. If only I could have fewer left hand turns on the way home and more highway miles.
OokiiMamoru is offline   Reply With Quote
Old 07-30-2008, 06:14 AM   #19
This actually part of the maintenance routine in some cars now. Honda is one.
Old 07-30-2008, 06:52 AM   #20
Even if the filter was still "good" I don't like the idea of mixing 4 quarts of fresh, new oil with 1 Qt of old, used oil... I'm really anal about my oil changes. I always pour 1 quart in the top of the engine, and let it run until clear, then reinsert the drain plug. I also fill up my oil filter with oil before installing it too.
Browse Vehicles Add-on jklaiber Fuelly Web Support and Community News 1 08-31-2008 01:07 AM
WTB: VX Cluster limerence Wanted to Buy 1 05-28-2008 07:45 PM
Second odometer for WVO tank? Jetta90GL Vegetable Oil and BioDiesel 2 03-24-2008 12:17 PM
