Stripped Oil Pan Bolt - Page 2 - Fuelly Forums
Old 09-18-2007, 10:27 AM   #11
Usually you would replace the gasket just so you don't get leaks. Especially since the old one is pretty old by now. Gasket is only 14 bucks I think.
Old 09-18-2007, 01:48 PM   #12
Send a message via AIM to Dave1215
let jiffy lube take it out, it will be a good learning experience for them.
they said "we don't do that" =[
Best Tank: 54.43 mpg
Dave1215 is offline   Reply With Quote
Old 09-18-2007, 03:28 PM   #13
omgwtfbyobbq's Avatar
Find the nearest metric or standard size socket and hammer it over the bolt so it'll have a force fit. Turn it with a breaker bar. Jiffy Lube should do it or pay for it since they were the last ones to work on it.
Old 09-18-2007, 03:55 PM   #14
lol does he have proof of that? i doubt it...
Old 09-18-2007, 04:00 PM   #15
GasSavers_Red's Avatar
Got a dremal or know someone who has one? could just grind new flats on the head
Old 09-18-2007, 04:10 PM   #16
Iono, I keep my receipts. I had g00dyear crossthread two lug nuts on separate occasions. The first time they were really nice about it, but the second time they gave me some crap about how they torque (or crossthread in this case) all their stuff to the manufacturer's spec.
Old 09-18-2007, 09:07 PM   #17
lol i thought someone would say that he had a recipt, which means nothing...sure it says they changed the oil, but thats it. even if dave says well they were the last ones to touch it! still no proof... how does jiffy lube know they touched it last?
Old 09-18-2007, 09:11 PM   #18
It's below or at the oil change interval with dirty oil in there. That being said, ya gotta fight, fer yer right, to get yer moneyz back. Enough complaining/filing with the BBB will get most large companies to come around.
Old 09-19-2007, 07:05 AM   #19
Another option, a muffler shop can weld a bolt to the drain bolt, then crank it out. Muffler shop probably won't want to do the actual removal though, since they usually don't have the facilities for an oil change. Might be able to get them to break it loose with an impact wrench without actually removing the plug, then go home and fix it. And, don't let those teenagers under your car again! All their claim of tightening to manu specs means is they have a book with the specs they can refer to when someone complains. In reality, they crank on it till it won't turn anymore, then they put the wrong oil in and leave the oil cap off.
Telco is offline   Reply With Quote
Old 09-19-2007, 05:25 PM   #20
or dont change the filter or leave the filter off...
Where's the Jeep Wrangler forum? Revolution Fuelly Web Support and Community News 2 04-16-2012 10:40 AM
Help! AlfieGT Fuelly Web Support and Community News 1 05-23-2011 12:35 AM
MPG, last 2 fuel ups read blank Draigflag Fuelly Web Support and Community News 4 04-28-2010 04:30 AM
Hi to everyone hawkgt647 Introduce Yourself - New member Welcome 21 04-09-2006 09:11 AM
