Starting problem - Fuelly Forums
Old 06-01-2008, 06:01 PM   #1
Starting problem
My 1988 Escort 1.9L TBI is hard to start first thing in the morning unless I operate the starter, cut the key off and let it activate the fuel pump for a second time. I am thinking maybe the fuel pump is about to go out. I have run fuel injector cleaner though it with no benefit in the starting. It runs fine once it starts. I know it is in the fuel system because after the fuel pump is activated the second time it starts right up. Any one have any other ideas?
Hipermiler
#47 on my way to #1
Old 06-01-2008, 06:40 PM   #2
Is it oiling the plugs from getting too much through the rings?
Edit: Oh if you haven't changed the fuel filter in years it might be an issue also.
Old 06-01-2008, 07:05 PM   #3
Your fuel system lacks pressure. Either it isn't maintaining pressure overnight (slow leak), the pump is slow until it warms up, or (if equipped) the automatic pre-pressurizer system (my VW runs the fuel pump when you open the driver's door) isn't running right.
Have you tried NOT turning it straight to "Start"? Turn it to "On", listen for the fuel pump or just wait a few seconds, then crank it.
My truck used to do the same thing, along with P0440 and P0446 codes, but now it doesn't anymore and I don't know why. It now has P0440 and P0453 codes and starts instantly...
Old 06-02-2008, 10:14 AM   #4
[QUOTE=RoadWarrior;103372]Is it oiling the plugs from getting too much through the rings?
Edit: Oh if you haven't changed the fuel filter in years it might be an issue also.[/QUOTE
I had the plugs out this morning checking compression on all cylinders. There was no oil on them and looked good. It could be the fuel filter.
Hipermiler
#47 on my way to #1
Old 06-02-2008, 10:18 AM   #5
I always turn to the on position and listen for the fuel pump before trying to start, but it still takes two times of activating it. It is OBD1 and has no codes pertaining to the fuel system.
Hipermiler
#47 on my way to #1
Old 06-02-2008, 03:23 PM   #6
its OBD 1 its not that smart, ive noticed you have to have some major issues for that thign to throw a code lol...
but change the fuel filter, if its clogged its just like a clogged air filter, makes whatevers tryign to push something thru it (especially fluid) hard to do, hence low pressure.
Pictures posted garyhgaryh General Maintenance and Repair 1 10-27-2007 08:57 AM
Car trouble woes Fourthbean General Maintenance and Repair 10 07-30-2007 05:54 AM
Mazda3 S Touring psyshack Introduce Yourself - New member Welcome 12 07-17-2007 09:34 AM
Volkswagen Diesel Quantum '84 zpiloto General Fuel Topics 10 06-14-2007 09:39 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 09:43 AM
