Squeaky Clutch - Fuelly Forums
Old 03-11-2008, 08:46 AM   #1
Squeaky Clutch
I have a 94 vx
the problem i am having is that when i let the clutch out somtimes it will squeak there is no slipping of the clutch and it doesnt seem to be chattery
it just squeaks right before it totally engages weather it be from a stop or on the move also somtimes it is worse and somtimes i can barely hear it. any ideas as to what this is will be appreciated
thanks
domggg is offline   Reply With Quote
Old 03-11-2008, 04:20 PM   #2
the bearing in between your clutch disk and the clutch fork usually is the squeeker. throwout bearing. and/or the lube where the bearing slides on may be dry. finally maybe your clutch petal is squeaking?
Old 03-12-2008, 08:21 AM   #3
Thanks i thought it could be the throw out bearing but wanted some more input ill check it out soon maybe when it gets a little warmer. im pretty sure its not the pedal but it cant hurt to check it
Old 03-12-2008, 08:07 PM   #4
kamesama980's Avatar
might be the clutch fork or whatever it's called in your is setup.
-Russell
Old 03-15-2008, 08:10 AM   #5
GasSavers_bobski's Avatar
Yeah... Depends on what kind of squeak it is. If, with the engine running, you can hold the clutch in one particular position and get a continuous squeak or squeal, it's likely the throw out bearing. If you only get the squeak when the clutch pedal is in motion, it could be a bushing or bearing at the fork's pivot point, or on the pedal assembly.
Old 03-15-2008, 03:28 PM   #6
yea, look under the dash with the engine off and push the clutch back and forth. if it doesnt make the squeak then most likely its the throwout
Average running mileage on dashboard mistakely same as last fill-up. MatrixDom Fuelly Web Support and Community News 3 06-15-2011 03:21 AM
Compression Test Q GasSavers_James General Maintenance and Repair 10 06-10-2007 06:40 PM
Hello People of Earth coastertoasterxb Introduce Yourself - New member Welcome 8 03-20-2007 06:56 PM
It happened again! Matt Timion General Fuel Topics 12 09-21-2006 09:26 PM
