Skooled by local mechanic - Page 2 - Fuelly Forums
Old 10-09-2007, 09:26 PM   #11
GasSavers_Randy's Avatar
It was just the initial adjustment. The 'automatic' part is only to keep them adjusted, and only then if you have normal wear.
You're supposed to lightly grease the contact points. Any manual says to, and I've seen dry and gouged backing plates. There's more force than from the little retainer spring. Think about it... there's so much force from the drum, even a tiny misalignment could force the shoes away from the backing plate when you hit the brakes. Bad things would happen. So they make it biased so they always get forced into the backing plate.
GasSavers_Randy is offline   Reply With Quote
change? lilspoon Fuelly Web Support and Community News 1 02-17-2012 12:13 AM
Potential Savings Per Fuel-up FAOGozalo Fuelly Web Support and Community News 4 03-01-2010 01:43 AM
Up stream pollution. omgwtfbyobbq General Discussion (Off-Topic) 0 01-09-2007 09:00 PM
