single or double fans - cooling system - Page 2 - Fuelly Forums
Old 03-07-2011, 06:22 AM   #11
theclencher's Avatar
Re: single or double fans - cooling system
You could try it first... I kept the fan and a wrench in the cab for about a year "in case I needed it". I finally hung the fan in the garage because there was only one occasion where it would have been nice to have.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 03-07-2011, 07:05 PM   #12
The rad now runs in single fan, it works fine unless AC is operated on continuously. There are temp sensors that work at higher temp than mine, so timing when it needs to kick in should not be a problem. I may need to use another temp sensor at the pressure cap, water at the top is hotter so it works earlier to start the fan spinning.
In here the idea of removing fans is not applicable, even though the car is moving free or driving in the night, ambient temp would never be able to cool off the rad. Perhaps this is to explain why AC generates heat, when AC is on it means hot air flowing from condenser to the rad and the work of the fan on the radiator becomes less effective.
thanks
GasSavers_Bluesky is offline   Reply With Quote
d15z1 into a Del Sol?? ravenrollercoaster General Fuel Topics 6 01-08-2008 08:24 AM
How well would a de-hybridized Insight peform (FE wise)? MetroMPG General Fuel Topics 21 10-10-2006 03:33 PM
