SGII someone guide me... - Page 2 - Fuelly Forums
Old 09-19-2008, 07:36 AM   #11
Originally Posted by Project84 View Post
I set, and saved, all vehicle info, engine size, fuel type, tank size, I even added 1 to the engine speed because I put slightly bigger tires on the car than OEM.
If your odometer is recording a different mileage than the SG, then your miles to empty etc. will never be right. Setup the SG so it shows the same speed as your speedometer. It won't be accurate but will be more useful.
GasSavers_landon is offline   Reply With Quote
Old 09-19-2008, 08:16 AM   #12
palemelanesian's Avatar
When filling up, I like to split the difference between pump gallons and SG gallons. That way, a single fillup won't spoil the next 2 tanks' readings. I also keep a running average of pump gallons vs uncalibrated SG gallons (back-calculated from my offset). It does settle down to the about the same numbers in both cases.
I have +10% gas (-10% mpg) calibrated on mine.
Electric lawn mowers bowtieguy Electric and Solar powered 38 04-07-2017 06:23 AM
pigfragger from NOCAL pigfragger Introduce Yourself - New member Welcome 3 02-28-2008 09:18 PM
Noooooooooooooooooooo!!!! unstable bob General Fuel Topics 8 08-17-2007 03:38 PM
worthwhile putting a 2.0 into a 3500 lb '85 Monte Carlo? MetroMPG General Fuel Topics 18 07-25-2007 04:01 PM
My last 3 fills popimp General Fuel Topics 4 07-15-2007 08:05 PM
