Seafoam lowered my idle! - Page 5 - Fuelly Forums
Old 11-14-2007, 10:50 PM   #41
Hateful's Avatar
Send a message via AIM to Hateful
I'm gonna get some to clean my Vortex Generators and Deturbulator tape.
Hateful is offline   Reply With Quote
Old 11-15-2007, 09:25 AM   #42
Originally Posted by TomO View Post
BIBI - does your VX idle that high when you have the climate control fan off along with the lights off and your foot off of the brake?
If everything is off, yes it will idle at 900 rpm, if a play with climate controle, brake or light it will go up to about 1000rpm...
Old 11-15-2007, 09:36 AM   #43
Originally Posted by Danronian View Post
I've heard of this method to do it, and have also heard of hydrolocking the motor using this method. If you read the can, it says to pour it VERY slowly and says nothing about stalling the motor. With a tiny 1.5L motor, if you poured 1/3 of the can down into the motor all at once, and somehow it all goes into one cylinder instead of evenly into all 4, I can see it doing some major harm. Just because it's combustible, isn't mean it will be able to be compressed in a liquid state.
If I was brave, and it was an old motor I had a replacement for, I would possibly try the "pour till it stalls" method, but I'm not in that situation right now.
And the cloud behind my car actually didn't form at all until I restarted the car after having it sit for the prescribed 5 minutes. I did use 1/3 of the can too, as stated is the max that should be used in my size engine.
But if you've used that method without a problem, congrats, I'm just scared when it comes to pouring liquid into the intake of my only car right now.
ive used my method 4 times now on a 2.2L and a 1.6L engine. it doesnt take much at all to stall an engine with seafoam. maybe a teaspoon in a vacum line will cause it to get very very bogged down. yea u dump a 1/3 of the can in when the engines not running sure ur gonna hydrolock it. thats why i said when it stalls out do not pour anymore and when it looks/sounds like its gonan stall stop pouring and let it catch itself up again. it can take up to a minute to get a 1/3 can in the engine.(usually the cloud appears before this tho...)
Old 11-15-2007, 10:35 AM   #44
Mayhim's Avatar
The LS1 in my Z28 was resistant to stalling doing the Seafoam thing. I just reached in and turned off the key when I reached that point. No tribble a'tall.
Old 11-15-2007, 11:34 AM   #45
any concern about the seafoam and the wideband o2 sensors the VX uses?
ive heard to never use it on an engine with a wideband because it can easily fail the sensor.
ive also heard that you are supposed to change the oil directly after using the seafoam because it will mix with the oil and decrease the viscosity like crazy, it has been decribed as similar to adding water to the oil, coincidence?
anyways, these are just some things ive heard when using seafoam, but it seems that you guys have had some good results
RobbieVX is offline   Reply With Quote
Old 11-15-2007, 12:24 PM   #46
bugsih's Avatar
I put some seafoam in the gas tank of my vx at 180K before i swaped motors and when I pulled off the intake manifold of the old vx motor where the injectors sprayed it was perfectly clean as well as the intake valves looked brand new.
bugsih is offline   Reply With Quote
Old 11-15-2007, 12:52 PM   #47
Danronian's Avatar
I was afraid of the same thing with the wideband, but I've heard of a lot of people on here using it, so I gave it a try. Luckily I have a back-up sensor if mine fails.
It does "water-down" the oil a lot, but I still ran it for a little while anyhow. It didn't seem to hurt anything. I know it says you can drive it with it in your oil for a while, but I like to just let it run in there for a little bit.
But overall, I've had great results with it, and it was the first time I've ever used it.
Old 11-15-2007, 01:43 PM   #48
cfg83's Avatar
RobbieVX -
To be super safe, couldn't you just remove it, plug the hole, and put it back? Orrrrrrrrrr, would the car revolt and not allow you to seafoam it?
Old 11-15-2007, 02:05 PM   #49
Danronian's Avatar
Originally Posted by cfg83 View Post
RobbieVX -
Hahahah
Yeah, that would have worked. I thought the seafoam might actually clean it a little and help make it read a little more accurately. Though I have heard any additives (like the stuff that already comes in my "winter" gas... ) are a terrible idea for a wideband.
Old 11-15-2007, 03:45 PM   #50
cfg83's Avatar
Danronian -
Hahahah
That sucks. It seems like you should be able to apply for a waiver or something. But a waiver is useless without a source for the "happy gas" for your wideband. Orrrrr, maybe an auto-store additive to neutralize the winter blend?!?!?!?!?!? Do Honda tuners care about their wideband sensors? If yes, then there might be an after-market solution. But, maybe I'm just trying to solve a non-problem .
Full tank of fuel or not? elvyn General Fuel Topics 9 03-24-2010 11:53 PM
Car trouble woes Fourthbean General Maintenance and Repair 10 07-30-2007 05:54 AM
XFi Drivetrain For Sale ... Perkasie, Pa XFi For Sale 17 12-17-2006 05:11 PM
Make the page lengths 30 posts again, please SVOboy Fuelly Web Support and Community News 4 05-18-2006 01:43 PM
Sticker Shock -- Inefficient New Furnace rh77 General Discussion (Off-Topic) 8 01-25-2006 07:15 AM
