Seafoam..>Do I need to change My SPARK PLUGS After? - Fuelly Forums
Old 10-07-2007, 07:36 PM   #1
panamacolin's Avatar
HI,
Today I seafoamed my car...1/3 in the brake booster line....1/3 in the crank case.....1/3 in the gas tank. Ran the car it smoked yada yada yada...im going to change my oil tomorrow...or should I run it a bit more and then change it. i have only driven the car about 15 miles since doing this...mostly at high rpms. Was reading online that I would need to change my spark plugs, the thing is the plugs are brand new, I just put these in, in the last 10 days.
Do I really need to change them?
thanks!
panamacolin is offline   Reply With Quote
Old 10-07-2007, 07:45 PM   #2
GasSavers_Red's Avatar
nope
Old 10-07-2007, 08:03 PM   #3
If your plugs are platinum, they should be squeaky clean after seafoam. If you are worried, check one like clencher says
And don't change your oil until you put another 10-15 consecutive miles on.
-unknown
Old 10-07-2007, 08:05 PM   #4
yea with seafloam in the crank you want to drive it hard (esentially screw gas milleage) so the oil PSI is high so it forces the seafoam along with oil thru all the ports and hopefully clean a buncha gunk out.
but ive never heard of seafoam doing anyhting to the plugs...
Old 10-08-2007, 03:20 AM   #5
I bought a can of Seafoam to clean my valvetrain before my next oil change. I called Seafoam to ask how much to add and for how long. They told me to use 1 - 2 oz per quart of oil capacity and drive the car for 100 - 200 miles before changing the oil.
Old 10-08-2007, 08:58 AM   #6
GasSavers_TomO's Avatar
pull one out
look at it
decide
^^^I'm with the clencher on that one. But if they are new, they should be fine.
Honda Civic VX Info/Links
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 10:17 PM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 04:08 AM
Picture / data issues fbobberts Fuelly Web Support and Community News 10 07-18-2009 01:11 AM
clutch problem VX McPatrick General Maintenance and Repair 9 06-25-2007 02:41 PM
Drafting behind a Truck GasSavers_roadrunner Hypermiling 20 12-24-2006 12:17 AM
