Seafoam? - Fuelly Forums
Old 06-27-2006, 11:35 AM   #1
GasSavers_Jack's Avatar
Seafoam?
I went and got sometoday. Of course then I start reading up on it and see the negative posts. Anyone have any negatives about seafoam? Or should I just do it and hope for the best.
See my car here:
Old 06-27-2006, 11:41 AM   #2
Matt Timion's Avatar
I don't think it's going hurt anything, but everything I've read says to use Auto-RX and to skip the seafoam.
Old 06-27-2006, 12:10 PM   #3
95metro's Avatar
Okay, I'll bite...what is it?
95metro is offline   Reply With Quote
Old 06-27-2006, 12:18 PM   #4
Here is a Honda-tech link to explain it:
http://www.honda-tech.com/zerothread?id=1502112
See my car here:
Old 06-27-2006, 08:49 PM   #5
|V3|2D
thisisntjared's Avatar
i use seafoam before every spark plug change. it cleans everything out very nicely and i have NEVER seen anything bad happen from using it.
one guy said he blew his head gasket and tried blaming it on sea foam but it was on its way out anyway with oil found in the coolant before hand...
Old 06-28-2006, 02:52 AM   #6
Compaq888's Avatar
seafoam is good. I did it on my previous car and it went with no problems.
Old 06-28-2006, 05:41 AM   #7
Moderator
GasSavers_DaX's Avatar
I seafoam my cars at least once a year, usually right before emissions. 1/3 in the gas tank, 1/3 in the crankcase, and 1/3 in the vacuum line. Change the oil after a few hundred miles (I usually time this right before an oil change).
This past year, I also poured (slowly) 20 oz. of water into my throttle body.
Old 06-28-2006, 07:53 AM   #8
I hear from others that have used it that it tends to clean out stuff from the gas tank and clog the fuel filter pretty quick.
Attachment 11
Old 06-28-2006, 12:22 PM   #9
Compaq888's Avatar
Then change the fuel filter after a couple weeks of running seafoam.
Old 06-28-2006, 05:49 PM   #10
where do you get some?
SupraRXZ is offline   Reply With Quote
Confusing engine selection choices ghammerly Fuelly Web Support and Community News 12 02-11-2012 09:14 AM
Gas cards to help track mileage? Pele2048 General Fuel Topics 3 08-12-2011 04:37 AM
Full tank of fuel or not? elvyn General Fuel Topics 9 03-24-2010 11:53 PM
Add Groups? ScoutTech Fuelly Web Support and Community News 3 03-17-2010 11:35 PM
im going to the track on thursday. anybody want to place some bets? thisisntjared General Discussion (Off-Topic) 14 04-14-2006 10:21 AM
