ScanGuage II problems - Fuelly Forums
Old 06-06-2008, 11:54 PM   #1
leetramp's Avatar
Unhappy ScanGuage II problems
Hi all,
I've had some problems with the MPG readings on my ScanGuage II on a 1999 Saturn SW. When I first installed the SG on my "new" (new to me, 94k) wagon, I found the MPG readings way too low (in the 20's, while I knew from fill ups I was getting high 30's). In a thousand or so miles, I played with it a bit, trying different things. Then suddenly it started working correctly. Unfortunately, I had been toying with it without really keeping track of what I did each time, so I don't know what I did last. But either way, I don't think there's really anything in the SG to set, other than the tank size which won't effect MPG.
So, everything was fine for a 6,000 miles or so, then I had to take off the SG, and suddenly I'm back to the problem of low MPG readings (again, I have checked this against actual miles and fill ups).
Any thoughts on what might be wrong?
Thanks.
leetramp is offline   Reply With Quote
Old 06-07-2008, 04:01 AM   #2
Well tank size and engine size. The little blue manual that comes with it also shows how to alter the readings a bit to better match what you are getting with your personal calculations to adjust for slightly variable tire pressure or tire size variations. You're "new" car may have had the original tires or rims changed out.
GasSavers_dan is offline   Reply With Quote
Old 06-07-2008, 04:36 AM   #3
If a computer lies to you, lie back at it until it speaks the truth LOL.
Just a joke
regards
gary
Old 06-07-2008, 08:56 AM   #4
you can got back to default setting and then you just start over. from main screen. from home pusy more, more , more then it should ask if you want to use defaults. then it'll be like when you first installed it. you'll have to set for tank size, etc.
Old 06-07-2008, 09:22 AM   #5
Hateful's Avatar
Send a message via AIM to Hateful
My tank MPG has been off too. Could it be the WAI with closed loop? I'm showng 32mpg but my gas needle indicates I'm doing better. I'm about 40mile to my next fill up.
Hateful is offline   Reply With Quote
Old 06-09-2008, 11:58 PM   #6
leetramp's Avatar
Thanks all. Yes, I forgot to set the engine size. All is fine now.
I was also please to notice that I can adjust the speed by 2% to match my non-OEM size tires.
Old 06-10-2008, 12:02 AM   #7
leetramp's Avatar
PS. A good web site for calculating the change in speedometer when you change your tires is http://www.miata.net/garage/tirecalc.html
200k dletm08 General Discussion (Off-Topic) 34 10-18-2012 09:08 AM
Acetone GasSavers_lane Experiments, Modifications and DIY 99 05-09-2008 07:07 PM
Old school cylinder deactivation MetroMPG General Fuel Topics 11 06-09-2006 06:29 AM
WAI revisited. zpiloto General Fuel Topics 14 05-16-2006 03:08 PM
Water Fuel System diamondlarry General Fuel Topics 0 11-14-2005 12:20 PM
