Sable Idle Speed - Fuelly Forums
Old 06-29-2007, 10:54 PM   #1
Send a message via AIM to cbmidi Send a message via MSN to cbmidi Send a message via Yahoo to cbmidi
Smile Sable Idle Speed
I fannally got my f/e up to 25 mph avg on the last 4 fill ups. I changed the plugs wires fuel filter, and air filter. But now the check engine light is on and the Idle seems a little high about 2500 rpm at park. I only seen it below 1000 once and that was at a stop light yesturday, but most of the time it stays at 2500 or above. oh yeah it is causing a premature shift at times.
cbmidi is offline   Reply With Quote
Old 06-30-2007, 04:57 AM   #2
Garage Entry
Hi...
I'd recommend a garage entry so we know what year the Sable is, engine, etc.
2500 is awful high -- that has to be racing! When you shift into Drive from a stop, does it lurch and take off? How about stopped at lights -- does it require a lot extra brake pedal pressure?
It should idle around 600-800 -- are you sure it's 2500???
Old 06-30-2007, 05:30 AM   #3
I'd check your Throttle Position Sensor(TPS) as well as the Idle Air Controller(IAC) .
Old 06-30-2007, 09:08 AM   #4
Smile
Originally Posted by rh77 View Post
Hi...
97 Mecury Sable 3.0 V6 # 3 speed trans with overdrive. Especally in the morning. I notices after it warms up it goes down alittle bit. 2000 RPM almost all the time except at traffic lights it slow to about 1000. I had Lumina z-34that was worse, I never did get that one fixed. I just want to prevent this car from gettung that bad.
Old 06-30-2007, 09:15 AM   #5
Sounds like the IAC to me . I'm not a mechanic though . iirc they are less than $30 at Autozone .
MID Install SVOboy Experiments, Modifications and DIY 33 06-04-2007 11:27 AM
XFi Drivetrain For Sale ... Perkasie, Pa XFi For Sale 17 12-17-2006 05:11 PM
Scangauge gets website upgrade ketel0ne General Fuel Topics 1 08-10-2006 06:52 PM
Make the page lengths 30 posts again, please SVOboy Fuelly Web Support and Community News 4 05-18-2006 01:43 PM
