rpm and highway speed in a CRX HF - Fuelly Forums
Old 10-15-2008, 02:16 PM   #1
Hi all,
I just have finished up redoing a 1990 CRX HF including putting in a new transmission. This was a rebuild and I specified that it had to be the HF gearing.
However now that I am up and running it seems as if it is geared high and I do not get the gas mileage I wanted.
I am running 174/65/14 tires which are a hair bigger than stock but not much.
In 5th gear at 60 mph the tach reads close to 3000rpm.
So anyone out there with a HF who can tell me what they get in the various gears.
That way i can tell if I have got the HF gear ratios I wanted or if the rebuilder used the non-HF gears.
Any help would be appreciated.
robtsp is offline   Reply With Quote
Old 10-15-2008, 02:42 PM   #2
You might have the same gears as this guy:
http://www.gassavers.org/showthread.php?t=9265
I seriously doubt your gears are too high. 3000rpm is far too much for 60mph, you should probably get higher gears so your rpm will be lower.
Old 10-15-2008, 02:49 PM   #3
GasSavers_Erik's Avatar
I bet you have Si transmission gears and/or final drive- I put an HF trans in my 87 civic and it runs about 2K rpms at 60mph. The original DX transmission ran about 2600 rpms at 60 mph.
Old 10-15-2008, 05:29 PM   #4
Good info guys. I think I got the high/low gear thing backwards. Bottom line it seems that the rpm should be lower for a given speed.
So guess I am back to the rebuilder to see what they put in it or if they admit to anything there. Anyone got leads on a used genuine HF trans?
Thanks
Old 10-15-2008, 05:30 PM   #5
You should be able to find one on car-part.com
drivetrain resistance bagpipe goatee General Fuel Topics 9 09-14-2008 10:04 PM
Time for new tires - Suggestions? maxxgraphix General Fuel Topics 1 04-18-2008 03:18 AM
Any Advice on Using a ScanGauge michaelburke Hypermiling 13 11-15-2007 03:38 PM
