Rim painting... - Fuelly Forums
Old 05-10-2006, 05:31 PM   #1
Rim painting...
Guess who ****ed up my paint putting my tires on...Anyway, how should I repaint? Totally redo it and take all the paint off or just sand down the ****ed up areas and hit them?
I'm so pissed right now, don't feel like messing with this ****.
Old 05-10-2006, 05:37 PM   #2
GasSavers_Diemaster's Avatar
Re: Rim painting...
than just get stealies. sleeper man :P
your not the only one. i put my almost new tires on my new optonal rims and nearly tore the bead in half i continued to put the tire on and it holds air and my fat *** in helga so i guess it ok when i do 103 in her :P
as for the paint i'd just touch it up. no one will notice from a distance.
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 05-10-2006, 05:40 PM   #3
I should've waited and
I should've waited and mounted them tomorrow at the shop during lunch. I guess tomorrow I can do the front suspension or something,
Old 05-10-2006, 07:36 PM   #4
mtbiker278's Avatar
soapy water
a little soapy water should help the tires slide onto the rim next time. I hear it also helps to seat the bead cause it allows just a tiny bit of wiggle room before it dries
mtbiker278 is offline   Reply With Quote
Old 05-10-2006, 07:48 PM   #5
I didn't mount them, when I
I didn't mount them, when I mount tires I use tire mounting lube spray,
Old 05-10-2006, 08:11 PM   #6
that sucks about the rim
that sucks about the rim scraping. you'll be able to fix it up nicely though. just re-do the rim part (i'm assuming that's where they scoured it).
Suggestion for alerting to new best MPG jostlehim Fuelly Web Support and Community News 2 07-15-2011 07:57 AM
Large Fuel Tank capacity JQL Fuelly Web Support and Community News 7 04-04-2010 04:52 AM
Side Gapped Spark Plug Life Span ? Gary Palmer General Maintenance and Repair 3 08-13-2009 03:43 AM
What made you an FE nut? 95metro General Discussion (Off-Topic) 19 06-12-2006 05:47 AM
Auto Show Season Begins rh77 General Discussion (Off-Topic) 9 02-10-2006 05:50 AM
