Resistance to turning from wheel - Page 2 - Fuelly Forums
Old 04-10-2007, 09:42 AM   #11
Originally Posted by BeeUU View Post
Naaaa dont bother. Really, you are fine, not worth the time.
(with a southern accent)
Now boys, you wouldn't happen to be givin' some bad advice to team members now would ya?
Just Playin...
That huge tank of helium in the hatchback really helps my FE. I actually passed a tractor-trailer with liquified helium and thought to myself if that was a light load. I had to smack myself with the owners manual after I actually thought about it
The Commish
Old 04-10-2007, 10:09 AM   #12
Semi-retired OPEC Buster
BeeUU's Avatar
The Commish
No sir, just helping the out-of-towner. Like y'all know, this is a freindly sorta thing. Yesum?
B W
BeeUU is offline   Reply With Quote
Old 04-10-2007, 12:27 PM   #13
I've had several incidences of the mechanical brake cable developing rust and binding in its housing. Applying the pedal or lever will pull the cable and engage the brake. The return spring in the caliper didn't have enough force to return the cable and fully release the brake when the pedal / lever was released.
The wear pattern described implies something misaligned or bent. Check the slide pins on which the caliper should 'float' or slide laterally to accomodate uniform pad wear.
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 12:25 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-21-2008 11:25 PM
Graphs itsastationwagon Fuelly Web Support and Community News 2 08-13-2008 02:04 PM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 07:27 AM
Sweden calling ! GasSavers_elg Introduce Yourself - New member Welcome 3 10-03-2006 11:17 AM
