Repairing metal fuel line - Page 3 - Fuelly Forums
Old 04-16-2010, 06:08 AM   #21
I know. But, think about it: If I had that much trouble getting this end of it unscrewed, what's next? I'll need to replace the fuel pump. What's going to be on the other side of that? Another seized fuel line. That will happen all the way back to the tank and I'll have to replace the tank too, if I want all my repairs to be 100% proper bolt-on using OEM-like parts. If I'm going to replace everything from the carburetor inlet to (and including) the gas tank, might as well do that TBI conversion while I'm at it!
That's why it makes sense to repair it in place. The rest of the system works fine as long as I don't try to disconnect it. I'll leave that investment for another time, after I determine that the car is viable.
Old 04-16-2010, 06:46 AM   #22
A tubing cutter will not work. I would have to remove the line from the car, and if I'm going to do that then it will be worth trying to find a complete replacement line (or having one bent). I'll also need a new everything else between there and the gas tank.
A small tubing cutter should fit in the space you have. I had (at least from what it looks like in your pictures) even less space on my Regal and used a tool like I linked below. My tool was maybe about 2" long and you should have enough "flex" in the tub to move it around to run the cutter around.
ben98gs is offline   Reply With Quote
Old 04-16-2010, 02:02 PM   #23
yea also something about a cutoff wheel that throws a few sparks and cutting a fuel line dont seem smart lol.
your gonna have a rubber fuel line between the body and engine somewhere or your fuel line would have broken within the first hundred miles from the factory due to the engine flexing.
either way those guys at the auto parts store must be idiots if they cant bend a simple tube lol
or just use copper for fuel lines, we have and its just as strong and a hell of alot easier to bend
you wont need to replace the fuel pump, even if the line gets broken again or mangled who cares your replacing it anyways haha (i actually think my chevettes has rubber lines on both sides of the fuel pump...)
spray some penetratign oil all over the line near the coupling and threads of it. it will eventually come out.
Old 04-18-2010, 11:15 AM   #24
Banned
zoop zoop you guys know about car-part.com right nation junkyard directory
Manual Shifters ManualFanatic Fuelly Web Support and Community News 1 07-16-2013 06:27 AM
savefuel.ca rangerbentman General Fuel Topics 4 03-08-2008 11:24 PM
A reminder about injector cleaning gto78 General Fuel Topics 29 03-07-2008 06:03 AM
New here, seems I've found my posse MakDiesel Introduce Yourself - New member Welcome 7 06-13-2006 07:09 PM
