When a car sits a lot, moisture accumulates in the oil. And if it never gets hot, the moisture never burns off.
The moisture accumulating thing is not always true!!!
Here's a good example for ya: I bought a '59 Chevy that hadn't been driven since 1968. Part of those years were in a garage and part were outside. So I start working on this thing right where it sits, to resurrect it and drive it home. I check the oil and what do I see? Nice clean honey-colored oil with no evidence of moisture at all!!!
That's 35 years of sittin'! (BTW, I put my first thousand miles on it with that oil and filter, and the old belts and hoses too!
AND I'm still running the original tranny fluid. Local trans shop guru told me to LEAVE IT IN THERE!!! He says the old whale-oil based fluids were
better.)
If that example isn't good enough, then there's this: I've been driving for 35 years and it was only in the beginning that I followed "all the directions to a 'T'". I discovered that not ALL the "pickling" procedures were necessary for over-winter storage. And I discovered that- in my climate anyway- time limits for oil changes were bogus. I go by mileage PERIOD. Sometimes my vehicles will go for a year or two or maybe even several years before they get an oil change; it depends on the mileage. Nope, NEVER had a problem with condensation or moisture or contamination or whatever it is you guys think goes horribly awry.
In case you're wondering, I have one car with almost 300,000m and several others with well over 100,000m. They are all going to rust away into nothing before the engines quit!
I do agree, though, that engines do need to be brought up to operating temp for oil to live. Might I suggest that if your trip is so short that your engine doesn't warm up, that you get off your *** and walk it?
