Rear Brake Drums for the VX, help deciding? - Page 2 - Fuelly Forums
Old 05-10-2011, 07:20 PM   #11
add|ct's Avatar
Re: Rear Brake Drums for the VX, help deciding?
Wow, that definitely sounds like a pain. Thanks for the heads up. I'll be careful with the brake line and may see if there is any play first before attempting the soak/removal. I believe mine 'may' be easier, but we'll see. At worst, I may just replace the one that I know had the gouge since it doesn't seem like the replacement seal seated itself well. So, failure during operation is 'somewhat' of a concern. More of an issue of slowly leaking brake fluid, though that seems to not be a problem currently.
Thanks for the experience and heads up! +1.
'92 Civic VX, Canadian model
Old 05-11-2011, 02:58 AM   #12
PB Blaster + patience + upside-down canned air + whacking it lightly with a hammer + flare wrench + turning both directions...
Or, if the car has never seen road salt, pliers. (No, not really.)
Old 05-11-2011, 07:51 AM   #13
add|ct's Avatar
^Ha, I used the method of inserting bolts yesterday to remove the one drum with the wheel cylinder suspect, and I gave myself a good blister before realizing pliers or a wrench would've been great once it was at the point of pushing off of the wheel hub. Ouch!
Old 05-11-2011, 04:09 PM   #14
its always best to replace both at the same time wheel cyl wise, if you happen to kink the line you might as well cut the other side of as its easier usually to replace both lines at the same time than one or the other, this also depends on your brake setup tho.
owning a chevette you get to know brake systems VERY VERY thoroughly, im sure anyone else who has knows what im talking about haha
Old 05-12-2011, 08:03 AM   #15
GasSavers_TomO's Avatar
hehehehehehehehe sounds easy on paper dont it?
most likely you wont be able to get the brake line out of the old one short of twisting the line till it kinks, then you gotta replace the line which can be a major pain in the butt.
This is exactly what happened to my VX when I went to replace a rear wheel cylinder due to a snapped bleeder valve. Had to go to the parts store, get a short straight chunk of metric brake line and bend up a new one.
Honda Civic VX Info/Links
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 12:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 01:50 PM
New Michigander bbanzai Introduce Yourself - New member Welcome 4 05-20-2008 05:04 PM
Any Toronto Peeps here? bbgobie General Discussion (Off-Topic) 0 06-15-2007 09:11 AM
