Questions about PCV - Page 3 - Fuelly Forums
Old 06-07-2006, 04:57 PM   #21
There's always the accord wagon or the civic wagovan,
The Fit is wagonlike in nature, I feel.
Old 06-07-2006, 05:13 PM   #22
Tuggin at the surly bonds
Silveredwings's Avatar
I'd love an Accord wagon...maybe an '04?
You can't get 'em in the U.S.: they don't burn enough gas for our culture.
Old 06-09-2006, 02:40 PM   #23
Compaq888's Avatar
Ok I tried to change it again and I lost about a gallon of coolant from the engine itself. I added coolant to the overflow tank, should I be scared that I will overheat my engine???
Old 06-09-2006, 03:18 PM   #24
I would bleed the air out of the system but if it's full with no air then it is fine.
My PCV system doesn't have any coolant in it.
Old 06-09-2006, 03:20 PM   #25
Compaq888's Avatar
Well I'm an idiot yet again. There is instruction in my FSM how to only drain and add coolant if I drained the system. My dealer was like add some water. Anyway since I have AAA I'm just going to have it towed to the dealer and pay $130 to get it done. I needed a coolant flush anyway, so this just speeds it up.
Old 06-09-2006, 03:22 PM   #26
Dude, just run it with the radiator cap off and bleed it, it takes a few minutes and doesn't involve doing anything in particular besides adding coolant as air bubbles come out.
Old 06-09-2006, 03:34 PM   #27
Comaq888: I am really confused. I thought you were trying to change the PCv valve. Their shouldn't be any coolant being lost. If you lost coolant, you should just replace it with a 50/50 mix of antifreeze and distilled water. I don't know what year your Nissan is, but almost everything I have is from around 90-94 and they use a little bleed valve at the top of the engine, where the upper radiator hose attaches. If it has that, just find a spot that has a little bit of slope, put the car up slope, running, let the bleed srew out until it starts letting air/cooleant out, then leave it until you get all coolant, then close the bleed valve. Then you should just need to put a mix in the overflow for the radiator and you should be good to go.
Old 06-09-2006, 03:35 PM   #28
Compaq: Are you talking about the radiator overflow tank?
Old 06-09-2006, 06:27 PM   #29
Compaq888's Avatar
The problem got fixed. Svoboy talked me through the whole thing. I bled the system and added fluid.
MiniStat Idea - Avg Miles / Day, Week, Month bullrider General Fuel Topics 1 10-28-2011 04:32 AM
some more familiar driving, LOL Compaq888 General Discussion (Off-Topic) 20 04-07-2009 01:37 PM
Too many entries W/ "0 MPG" DPTyphoon Fuelly Web Support and Community News 7 09-13-2008 02:19 AM
Commenting on tips MartinL Fuelly Web Support and Community News 0 08-30-2008 06:07 AM
Fuel Economy and Lease Mileage RespecttheT Fuelly Web Support and Community News 2 08-14-2008 06:42 AM
