Question: Higher idle after spark plug replacement - Page 3 - Fuelly Forums
Old 07-16-2008, 10:03 PM   #21
suspendedhatch's Avatar
Those Bosch plugs are junk and will give you nothing but problems with a Toyota. Toyota's are known to be picky about spark plugs. I suggest getting the regular old NGK plugs or factory Denso.
Check ignition timing and reset the ECU. Make sure your throttle cable isn't binding.
Old 07-17-2008, 07:21 AM   #22
Got any proof of that? Links? I've run Bosch plugs in my 88' Toyota with zero problems.
Granted, you may not see any more performance than you would from a set of normal Platinum plugs. Calling the plugs junk is a little far. The thought process behind these +2 plugs and theory is sound. Just don't think it works as well in the real world as it looks to on paper.
- Kyle
US / metric switching problems gory Fuelly Web Support and Community News 4 01-24-2011 03:04 AM
Tracking Monthly Fuel Expense Taser Fuelly Web Support and Community News 2 11-10-2009 12:40 AM
Picture / data issues fbobberts Fuelly Web Support and Community News 10 07-18-2009 01:11 AM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
pulse up or pulse down a hill, higher or lower gear perris Hypermiling 9 07-16-2007 10:33 PM
