Question about GM truck blower motor wiring - Fuelly Forums
Old 08-24-2009, 05:41 PM   #1
Question Question about GM truck blower motor wiring
Medium High speed just went out in my truck (The one I almost always use). Chances are its a wiring problem at the resistor strip, but I've never had to work on a resistor strip on one of these newer model vehicles. Its not near the firewall where I'm used to finding them. I suspect it may be under the dash somewhere, but I'd like to know exactly where to look before I started indiscriminately ripping the dash apart.
Thanks,
Jay
Old 08-24-2009, 06:19 PM   #2
My 2002 has a plethora of electronics screwed to the backside of the HVAC control panel...have you checked directly behind yours?
Old 08-24-2009, 06:51 PM   #3
Typically the resistors are located where they will get good airflow for cooling, if they are the old style that generated significant heat.
regards
gary
Old 08-24-2009, 08:29 PM   #4
HC - No, I was holding off tearing the dash apart until I knew what area I should be tearing apart.
Old 08-24-2009, 10:17 PM   #5
The newer S-10s have them on the firewall, mine has it buried on the motor. I'd assume since you have a "newer" Sierra, it'd be the same. If it's not on the firewall near the intake or AC exchanger, I'd assume its on the blower housing, buried under the dash. I only have the 2 fast settings on mine, just not worth the hassle of ripping the dash off to find the resistor.
almightybmw is offline   Reply With Quote
Old 08-25-2009, 04:23 AM   #6
Yeah, most people would just say oh well, and leave it with 1 speed not working, but I make a point that everything on my cars work. The only thing that does not work on any of my cars is the cruise control on the Buick, and that's because the resume solenoid is broken, and I cannot locate a replacement. Because of that, the car "resumes" the second you take your foot off the brake. I ended up disconnecting the cruise for obvious safety reasons until that part can be located.
Partial fuel-up - when do you reset your trip odometer? johnclayton Fuelly Web Support and Community News 2 07-30-2009 10:16 PM
What is the FE sweet spot for... bowtieguy Transmissions and Running Gear 14 09-05-2008 07:18 AM
Maximum tire pressure holypaulie General Fuel Topics 13 10-02-2007 08:25 AM
Aero mods - Volvo wagon brucepick Aerodynamics 19 06-18-2007 03:42 PM
