Preventing crummy brake rotors when parked outside? - Page 4 - Fuelly Forums
Old 11-02-2007, 10:30 AM   #31
The rotors *will* die
I think the responses are varying by climate and I think your rotors are doomed
The pulsing and grinding are the most noticeable symptoms but if you can get a look at the inboard side of each rotor you may see that side rusting up more completely. That "invisible" side of the rotor rusts faster because the spash shield doesn't allow the air to circulate as much.
I have seen rusting that reduced the shiny surface to about 1/2" radially on the inboard side of the rotor.
The only solution is to drive the vehicle more or store it in a dry garage.
css28 is offline   Reply With Quote
Old 11-02-2007, 10:38 AM   #32
Bruce, I have to admit I've been toying with the idea of selling the car, especially now that I have the "electric umbrella" for local trips when needed.
Since January I've only driven it about 3500 km. Makes for a really poor $/km analysis. And for thwapping rotors, obviously.
css28: now you've got me thinking I should pull a wheel and have a look - see just *exactly* what's going on, instead of doing this by ear & by feel.
Old 11-09-2007, 07:35 AM   #33
Mayhim's Avatar
I had that problem really bad on my truck. The rotors and pads glazed over after many cycles of rusty braking.
I got everything together and started a brake pad change when I discovered it was just glaze. The pads weren't very bad at all. I went ahead and did the change though - the new pads had a compound on them to break glaze and bed in the new pad/rotor combo.
In the future should this happen I'll just give the pads & rotors a quick lick with the flapper wheel to my 4 1/2" grinder to break the glaze and get everything right again.
Other than that, I really don't think there's anything else you can do to stop surface rust short of stainless or other type rotors.
Old 11-25-2007, 09:54 PM   #34
kamesama980's Avatar
Originally Posted by Coyote X View Post
Then again as little as you use the car you might want to oil soak the pads anyway, it will reduce rolling resistance and you don't hit them hard enough to worry about needing real strong brakes most of the time.
deer god please tell me you're joking cuz when little molly chases her ball into the street in front of you I doubt the judge will like that forensics found your brake pads were oil soaked and roters and wheels had residue with no oil leaks in evidence.
-Russell
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 01:49 PM
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 01:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 02:50 PM
Weight of Gas Hockey4mnhs General Fuel Topics 15 12-14-2006 10:37 PM
