Power steering on a VX? - Page 2 - Fuelly Forums
Old 05-04-2008, 09:17 PM   #11
suspendedhatch's Avatar
The DX hatchback automatics came with power steering. Many VX's came with A/C, especially in California and possibly other states like Florida.
To swap in power steering, you need the PS rack, pump, lines, resevoir, lower crossmember, and the U joint that connects the rack to the steering column. Doing so will drop your freeway mileage about 4mpg.
The cars that came with power steering have what's called an idle-up response to load put on the motor by the PS pump. There is a similar feature for the AC. If you're idling and you turn the wheel slightly, the engine will bog down a bit and the rpm's will drop before the ECU can respond. In an extreme situation the engine may stall. So there is a little sensor in the PS rack that detects pressure and increases the idle speed in anticipation of this added load. If you do a conversion you will not have this feature because the P07 was never intended to be paired with power steering.
Over 100 Gallons twbhd04 Fuelly Web Support and Community News 14 06-20-2011 09:09 AM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
Electric bikes banned in Chinese city to make room for cars MetroMPG Electric and Solar powered 4 11-24-2006 08:29 AM
Awesome, awesome, awesome: recumbent "tri-brid" - human/electric/sail MetroMPG Electric and Solar powered 4 11-03-2006 04:02 AM
