Power loss while cruising in Saturn - Fuelly Forums
Old 10-09-2007, 11:49 PM   #1
On one of the first days of driving my car I noticed that while cruising at 55 I would lose power for a second or two and then it would come right back. I watched the tach the next time it happened to make sure it wasn't the clutch giving out. The tach was stable the next time so I started paying attention to the engine.
This morning it did it a few times and I think that it is driving with almost no load at 55 that kicks it off. It's almost as if the fuel injectors can't squirt a small enough portion of gas so they miss and the engine loses power, if I give it a little more pedal the car comes back to life.
I am going to grab some fuel injector cleaner to see if that helps any, I have seen some threads about sea foam also. Would that do the same thing? My oil change light came on so I could put some in my oil also and clean that out while I am at it.
Old 10-10-2007, 05:58 AM   #2
trebuchet03's Avatar
Clogged fuel filter not getting enough pressure to the injectors?
11/12
Old 10-10-2007, 07:59 AM   #3
Hmm, didn't think about a fuel filter. But doesn't the electronic fuel pump always keep the same amount of pressure on the system? If that is the case I would think this would be a problem under acceleration from not enough fuel rather than under extremely light loads as it is.
I will look for the fuel filter anyway though, as I am quite sure it hasn't been replaced before and now is as good a time as any.
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 10:26 AM
A side project I am working on... DTMAce General Fuel Topics 3 04-29-2010 02:21 PM
Diesels are very efficent at idle? philmcneal Diesels 36 04-05-2007 06:25 PM
Recommendations for a tire gauge Compaq888 General Fuel Topics 10 04-21-2006 02:18 AM
