Performance Underdrive Pulleys? - Page 2 - Fuelly Forums
Old 09-08-2007, 09:04 PM   #11
Snax's Avatar
Let's just put this into more concrete terms on some arbitrary efficiency numbers:
Assuming your accessories sap about 20% of your efficiency at idle, a 10% underdrive pulley is going to improve overall idle efficiency by roughly 4%. A 20% underdrive bumps that to 8% at idle.
I think it's fair to assume that the inefficiency of running the belts through a tighter bend is relatively minor - particularly if you upsize one or more of the accessory pulleys being driven.
I think it's also important to note that the improvement I suggest is at idle only. As rpms increase, you get into the accessories like power steering pumps and alternators bypassing/reducing their load on the system. So while one may see a 10 or 20% improvement in efficiency at idle, that won't translate directly to higher rpms - unless something like a clutchless fan is being driven.
Based on that, there should be a measurable improvement, but higher rpm running will limit it.
LiberalImage.com
I think, therefore I doubt.
Login Error! Can't login via mobile web cornfieldcraig Fuelly Web Support and Community News 9 10-06-2014 09:11 PM
fuel economy question Creamycaesar General Fuel Topics 19 02-08-2010 08:37 AM
Currency SirTK Fuelly Web Support and Community News 3 11-27-2009 01:25 AM
FS: honda vx final drives 3.25 and vx 4th gear GasSavers_bense For Sale 0 08-28-2006 11:06 PM
