Matching and/or englargening ports went out of style 30 years ago.
Originally Posted by Ted Hart
Ahem! Is this what you really said? If we regard an engine as an air pump, with production tolerances being (as loose) what they are, then we can ignore all the turbulence-causing steps, ID /OD mismatches, jammed up port cross-sections, rough walls, flashings, poor design curvatures (bean counter me$$), and the like? NIMBY...! I like smooth,non-twisting paths for my airflow. Requires less power, too! After all, 14.7 psi ain't gonna push in but so much "air"... even under ideal (ported, polished) conditions. I'll admit, low RPM work isn't bothered by this, but if you try to make serious power...you'll need good airflow.
Hi Ted :-)
¨Ahem! Is this what you really said?¨ - YES , i said exactly that.
¨If we regard an engine as an air pump¨ - we cant assume that under all circumstances.
¨with production tolerances being (as loose) what they are,¨ - Are they ?? - I dont think so.
A production tolerance means that a specification may vary within an allowable percentage.
When talking dimensions of a crankshaft journal for example , a tolerance could be between 1.5 and 2.5 thousands of an inch, which as you would agree is small in relation to the journal size.
This possible variation in size is tolerance.
Having a manifold mismatch of 5mm is NOT production tolerance.
¨rough walls, flashings¨ - in an inlet manifold for example these have little influence on total flow.
¨poor design curvatures¨ - Under most conditions even a 90 degree bend in an inlet or exhaust manifold wont seriously affect flow as long as the area remains the same.
¨I like smooth,non-twisting paths for my airflow. Requires less power, too!¨ - as most of the air flows in the centre of the manifold , umm hole , surface texture has minimal effect on flow. Twisting paths as i said earlier have minimal effect if the area is unchanged.
This manifold has a few twisty bits., but ime sure it flows well.
¨but if you try to make serious power...you'll need good airflow.
¨ - well . I was making 100+ horsepower per litre engines about 25 years ago now , with no EFI , turbos , twin cams ,4 valves per cylinder or variable cam timing.
With turbos I have made 200 hp per litre.(but still no twin cam or 4v) , and I must add that these were normal road cars , with good road manners not some undrivable track racer.
Ime not blowing my own horn here , but I think that shows that I know a little about how to make power.,,
The fact is , that most power gains with porting are done with work within an inch of the valves head., Cutting and grinding excessivley further up the intake port rarely makes more power , but effectively screws bottom end drive ability.
As flow benches have become more common the idea of huge ported and polished ports are dead and buried , this has been proven time and again.
