Open vs. Closed Loop - Fuelly Forums
Old 09-18-2008, 05:42 AM   #1
I'm trying to clarify something. From what I've read open loop is when the engine is using a default a/f mix, and closed loop is when it is using an a/f mix based on the reading of the O2 sensor and such.
O know the engine runs in open loop until it is warmed up.
Once warmed up should it stay in closed loop or should it be cycling between open and closed depending on throttle, gear, etc?
I ask because I was noticing that Box cycles back and forth, but I have no idea if that is normal or not.
Think inside the Box!
Improbcat is offline   Reply With Quote
Old 09-18-2008, 06:11 AM   #2
I was always under the understand that once in closed loop (when warmed up) that it stayed there except for WOT. Probably about 90-100% of throttle it ignores the O2 and just starts dumping in extra fuel.
I've never had a meter to actually verify this on any of my cars though. My father has a Chevy scanner and I know our trucks stay closed once they close as does his Caprice.
I'm not sure about your car since it's a lot newer, I'm sure most new cars just read the TPS, but on my old Audi there was actually a switch at the end of the physical throttle movement, if this was adjusted too far in you could be hitting at 50-60% throttle maybe? Or actually just check your TPS, measure resistance at 0-50-100% and see if it lines up with what others report.
Old 09-18-2008, 06:29 AM   #3
Arrow
Originally Posted by itjstagame View Post
I'm not sure about your car since it's a lot newer, I'm sure most new cars just read the TPS, but on my old Audi there was actually a switch at the end of the physical throttle movement.
Are you sure that's what that switch is for? My old 1980 Bonneville had a switch at the end of the throttle travel as well, when the switch was activated the transmission kicked down to a lower gear. That switch seems kinda redundant on a newer car as the computer already knows how much the pedal is being pushed from the TPS.
Old 09-18-2008, 06:45 AM   #4
Right that's why I suggested to check the TPS. Well my Audi was manual and I know for a fact when the switch was pressed that it goes to WOT, but the Audi isn't a good example of anything because it didn't have a TPS and measure fuel requirements with a flapper :-).
Old 09-18-2008, 07:31 AM   #5
palemelanesian's Avatar
My 1996 Civic goes to Closed Loop after about 10 seconds from a cold start. Warm start and it's almost immediate. It switches to Open Loop above about 95% load / throttle.
...according to Scangauge.
Old 09-18-2008, 10:18 AM   #6
Would a bad TPS possibly cause this? Also the idle is uneven when in neutral and stopped, it drops til the engine nearly stalls then jumps back up to over 1000rpms, then drops steadily again.
Old 09-18-2008, 04:07 PM   #7
This is how the 02 sensor is supposed to work. Sometimes it will even go to closed loop before the engine is totally warmed up to normal running temp, as long as it does not need the extra rich fuel mixture.
Could be something wrong with the 02 sensor if it is continually running open loop and wasting fuel.
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 09-18-2008, 07:28 PM   #8
Almost sounds like a vacuum leak somewhere. My grandfather's Grand Marquis did that and the dealer found a cracked vacuum tee under the hood.
Old 09-18-2008, 07:42 PM   #9
2000mc's Avatar
bulletin - EG012-04
INTERMITTENT ROUGH OR LOW
ENGINE IDLE AT A STOP
A small number of 2004 model year Scion xA and Scion xB vehicles equipped with manual transmissions may experience an intermittent rough or low engine idle at a stop due to a possible misadjusted throttle cable.
2000mc is offline   Reply With Quote
Old 09-19-2008, 05:58 AM   #10
Originally Posted by 2000mc View Post
bulletin - EG012-04
That sounds exactly like my car. I dug up a copy of that TSB online and will have to look into it.
Sadly it also sounds like I've got another issue what with the going in and out of closed loop.
Default Car? jerryc41 Fuelly Web Support and Community News 2 04-04-2011 03:32 PM
Vehicles excluded from graph? jostlehim Fuelly Web Support and Community News 4 12-11-2010 03:24 PM
Synthetic motor oils and MPG TONYPR70 General Fuel Topics 13 01-06-2009 06:36 AM
BMW C.L.E.V.E.R. Concept MetroMPG General Fuel Topics 4 04-24-2006 11:59 PM
