After having my oil chaged at a Wal-Mart lube center, my car started smoking from the engine compartment. Oil also began leaking from around the valve cover.
Turns out they overfilled the engine with oil ( but by only half a quart )
I drove the car around 40 or so miles before it started smoking, and then quickly drained the excess oil.
As of around 4 monts ago, I also changed the gasket ( which when I pulled off looked undamaged
What I'd like to ask about is why that I am still getting oil leaking into the # 1 and #4 spark plug chamber.
Is there an additional gasket that I missed or something ?
Also, what damage could this do to the engine ( having the oil leak into the spark plug chamber )
I would think that since the spark plugs screw in tightly and seal the chamber from oill leakage, that it would not really have an effect except to make the spark plugs oily when I go to pull them out.
Am I wrong in assuming this ?
Any advice would be appreciated.
Thanks !
