obd0->obd1 distributor wiring harness - Fuelly Forums
Old 11-03-2005, 08:52 AM   #1
Matt Timion's Avatar
The following is all Honda talk.. sorry
While I wait for the ECU pinouts for a pm6->p07 conversion harness I decided to just start making a distributor conversion harness for when I upgrade to obd1.
The only problem is that I can't find a good pin to pin guide. i would like to be able to find a resource that tells me exact which wires are which between the two plugs.
So does anyone know the wiring to make a distributor jumper for obd0->obd1?
Old 11-09-2005, 08:32 PM   #2
I had to do this same wiring
I had to do this same wiring when I put a Type R motor in my 91 civic. I found that all of the wire colors matched up from the OBD0 distributor wiring on the engine harness and the OBD1 wires on the distributor. There are two white wires in the OBD0 harness that are hard to differentiate. If the car does not start, switch the white wires and it will start.
red civic standard is offline   Reply With Quote
Old 11-09-2005, 08:57 PM   #3
Re: I had to do this same wiring
Thanks man. I was talking to Diemaster about this and he just told me to match the colors like you said.
I'll wait until I actually do the swap though as a LOT of wiring is going to have to be changed when this thing gets done.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 08:48 AM
How many clicks to fill up? tarheel8 General Fuel Topics 10 12-07-2011 08:25 AM
Tracking my MPG on my 2007 Honda Civic EX jonswifey General Fuel Topics 12 08-13-2011 09:31 AM
initial fill up knhobson Fuelly Web Support and Community News 5 02-02-2010 05:13 AM
