o2 sensor woes - Fuelly Forums
Old 06-09-2009, 07:40 PM   #1
o2 sensor woes
ok so i got the dang thing wired up and still got a code 48 on my 92 vx does that mean i need to buy a o2 sensor
tapwc19 is offline   Reply With Quote
Old 06-10-2009, 07:42 PM   #2
jadziasman's Avatar
When you say you have a code 48 does that mean that after you reset the ECU to clear the code, the CEL comes back on right away after starting your car with code 48? Or does the CEL come on at unpredictable instances?
I had an intermittent code 48 on my VX that would come and go with increasing frequency over a three year period. Once the CEL kept coming on every couple of weeks I decided to change the LAF to a lightly used OEM one from a high performance tuner shop and have not had a code 48 for seven months now.
So yeah, it could be that your LAF is triggering the CEL.
Old 06-11-2009, 04:33 AM   #3
it comes on about 35-40 seconds after starting and stays on till i kill the car and then the same thing all over again i tried to monitor it per instructions in tomo s post on that and the reading is always -.77
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 04:38 PM
Tail pipe restrictor test GasSavers_Erik Experiments, Modifications and DIY 36 06-14-2008 07:09 PM
New Japanese Crap Request Thread SVOboy General Discussion (Off-Topic) 10 07-01-2007 04:34 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 03:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 04:43 PM
