O2 sensor voltage fluctuation wildly - Fuelly Forums
Old 09-19-2007, 07:49 PM   #1
I have a 95 geo metro. It has a 4 wire O2 sensor. My millage has not been what I think it should be so I hooked a multimeter and a air/fuel mixture gauge up. The voltage and gauge fluctuate wildly from most lean to most rich. I am sure it is not a loose connection. Does this mean the O2 sensor is bad?
Thanks
Giovanni is offline   Reply With Quote
Old 09-19-2007, 07:50 PM   #2
No, usually narrowband sensors flick back and forth rapidly and the ecu extrapolates a middle point. It's weird but that's how it works.
Old 09-19-2007, 08:05 PM   #3
Bunger's Avatar
It could be bad if it's taking a long time for it to "flick" back and forth. The faster it responds the better mileage you'll see.
Anger is a gift!
- Zack de la Rocha
Old 09-20-2007, 01:03 AM   #4
Team GasMisers5!
landspeed's Avatar
When I had a SuperMID on the Micra, the injector pulse width would fluctuate back and forth, when cruising with a perfectly constant throttle load - again due to the O2 sensor I guess.
Hypomiler
Old 09-20-2007, 11:52 AM   #5
cfg83's Avatar
Giovanni -
Like SVOboy says, narrowbands fluctuate all over the place. On my Saturn, mine fluctuates up and down all the time, but it seems to cheat from 14.6 and up after the engine's all warmed up. When I am in steady-state cruising, the swing is much smaller, maybe 14.6 to 14.9 most of the time.
EDIT : Correction, the 14.6 to 14.9 is the digital/numeric display sample over a longer time period. So I still see the fluctuation. If I get a chance, I will make a youtube of it.
Old 09-22-2007, 06:39 AM   #6
Thanks for the replies. I guess that little gauge is useless then so back it goes. I am only getting about 41 mpg out of this car and am stumped. I have changed the plugs, dist. cap, and wires. New filters and all to no avail. Any ideas?
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Can fuel descriptions associate with mileage at *next* fuel-up? anthill Fuelly Web Support and Community News 2 01-30-2011 10:32 AM
Are Algae the Future of Energy & Biodiesel? Ecacophonix Vegetable Oil and BioDiesel 0 05-16-2007 10:40 AM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
