O2 sensor failure modes? - Fuelly Forums
Old 08-27-2008, 02:43 AM   #1
Hi folks,
Marvin decided to take a funny turn and run like a bag of nails, one of the codes I'm getting if for the O2 sensor, a code 21, which on this model year appears to mean that the O2 voltage value is stuck in the middle somewhere.
I'm thinking "what the hell?, don't they just fail lean???" so this seems highly bizarre. There's other codes for constant rich or constant lean. I realise of course that this might not be the O2 sensor per se but some other fault, particularly as I'm getting a code for the speed/distance sensor at the same time.
Some sources say for 90 up the code means O2 sensor "stuck at value" and no mention of whether it's middling high or low. Either way, seems very odd I'm not getting a code for constant lean or constant rich as well if that's the case.
Really don't have much of a clue what's going on yet, I'm suspecting an issue in the speed/distance sensor circuit that shares a signal ground with the injector timing, TPS etc, that is taking out the SDS and buggering up the fuelling.
Any clues greatly appreciated.
Road Warrior
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Tail pipe restrictor test GasSavers_Erik Experiments, Modifications and DIY 36 06-14-2008 06:09 PM
New Japanese Crap Request Thread SVOboy General Discussion (Off-Topic) 10 07-01-2007 03:34 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
