O2 sensor failure modes? - Page 2 - Fuelly Forums
Old 08-27-2008, 06:05 PM   #11
That's on my to-do list for tomorrows poking, real hard to get live signals without stripping wires Haven't got 100% accurate diagrams and service data, having to trace wires on the vehicle to be sure.
Old 08-28-2008, 07:39 AM   #12
Well I picked up an O2 sensor, old one is loose in it's bushing and venting exhaust gas, which probably means it's getting very little backside oxygen to balance the cell, which probably means it's running rich. So it needs an O2 sensor, just hope it fixes the issues.
This is a three wire, grounded through it's case, apparently later ones went to a 4 wire with dedicated signal ground. Hmmmm. If the ground floats a little high though, that means it reads a tad rich, which leans mixture, so I'm thinking "maybe that's good". But I might make a copper gasket with a crimp connector tab on it, so I can strap it to a better ground if necessary.
Old 08-28-2008, 07:52 AM   #13
GasSavers_Erik's Avatar
If it was loose, it could have been drawing in a little bit of fresh air via the vacuum between exhaust pulses.
If so, the sensor would see the fresh air coming in and tell the computer the mix was too lean and so the ECU would richen it.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 04:38 PM
Tail pipe restrictor test GasSavers_Erik Experiments, Modifications and DIY 36 06-14-2008 07:09 PM
New Japanese Crap Request Thread SVOboy General Discussion (Off-Topic) 10 07-01-2007 04:34 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 03:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 04:43 PM
