New VX owner. Embarrassing question. - Page 2 - Fuelly Forums
Old 08-21-2012, 03:58 PM   #11
Re: New VX owner. Embarrassing question.
Originally Posted by notorious_eg View Post
it is offset to the driver's side slightly...
This is really helpful. Thanks.
imawakenow is offline   Reply With Quote
Old 08-23-2012, 01:35 PM   #12
Forgot to mention the very front jack point is the one that is offset towards the driver's side - the rear one is in the middle just as pictured...
notorious_eg is offline   Reply With Quote
Old 09-07-2012, 09:55 PM   #13
Wow. It's REALLY off toward the driver's side. Enough so that the chassis of the car twists a good bit when lifting from that point. Scary.
So I guess I have to invest in that full hydraulic lift now ...
Old 10-22-2012, 09:08 PM   #14
I always place my jack under the front tow hooks and a jack stand under each point by the doors. If the tow hooks are bent invest in some new ones.
jmaze is offline   Reply With Quote
Old 10-26-2012, 06:05 PM   #15
GR8MPGcrx's Avatar
Did not realize jacking up a car could be so confusing. I usually jack up my car from underneath some-were between the wheels on that lippy thing, and I also throw a old tire, or a hay bale underneath the car...... You can never be too careful
GR8MPGcrx is offline   Reply With Quote
Old 12-02-2012, 11:01 PM   #16
Haven't stopped by here in a while. I did pull off both rear trailing arms, swapped out RTA bushings, and rebuilt the drum brakes on each side. Exciting stuff! Now I just have to take off the integra front knuckles that are on the car and put on Civic ones so I can fit my 13" rims on there.
And that will require jacking up the front. The tow hooks is a good idea, thanks for that, but as far as jacking up both sides do you do one at a time or what? BTW I put my jack stands where you do and have never had a problem with that.
Again, the reason I'm asking about this is because there's no CENTRAL jack point in the front and the metal beam under the radiator seems a bit flimsy. Also don't want to crack the plastic under the bumper or have to remove it just to jack up front of the car.
Old 12-10-2012, 04:52 PM   #17
OK, finally got it. Lift from a tow hook, place jack behind wheel, repeat on t'other side. Duh.
The VX is the first Honda I've seen without an obvious jack point front and center. Threw me for a loop.
VX at the track IndyFetch General Discussion (Off-Topic) 16 05-28-2010 08:00 AM
Vehicles with cheapest parts cost theholycow Transmissions and Running Gear 20 12-28-2009 10:08 PM
Solar Collector Could Change Asphalt Roads Into Renewable Energy Source OokiiMamoru Electric and Solar powered 0 10-16-2008 05:43 AM
Fuel Enhancer which saves you money fsanti01 General Fuel Topics 9 06-13-2008 06:06 PM
