New exhaust makes ping noises randomly - Fuelly Forums
Old 08-18-2008, 10:21 AM   #1
I just bought a 1993 VX a couple weeks back and the exhaust system was a mess so I knew that was the first thing I needed to do. I took it directly to Bell Tire and had them put a whole new exhaust system on. It sounds much better and looks good however from time to time I hear a ping noise. I especially notice is when I park and turn the car off. It doesn't happen often but its very strange. Any idea what this could be? Should I be concerned?
Thanks!
thegreatconduct is offline   Reply With Quote
Old 08-18-2008, 10:28 AM   #2
Thermal expansion (and contraction as it cools). You can't hear it as it heats up due to the engine running. It's normal. It'll go away in a year or two as it starts to rust and the joints fuse to their mates.
Old 08-18-2008, 10:31 AM   #3
Thanks for the quick reply! I thought it might be something like that but wasn't sure. One less thing to worry about.
Old 08-18-2008, 10:36 AM   #4
This commonly happens when they don't use flanges that hold together with springs.
I would stay with the solid flanges because, like in my car's case, the gaskets don't seal right after a while unless the exhaust is hot. Makes the car stink if you are using fresh air on the ac when you start the car cold.
- Kyle
