Need Help Troubleshooting Lines - Fuelly Forums
Old 01-27-2009, 12:28 PM   #1
Okay so after installing my 02 and ecu for my crx hf, my cars been achieving about 35-38 mpg. It does idle at around 1250-1500 rpm which seems kind of high to me so I think that might be because of some of my vacuum lines. In any case, I believe that some of my vacuum lines are either not installed properly or installed at all. Please refer to the picture to help me out as to how to install and place them in their proper spots. I might also add that if you look at one of the pictures, the plug is not installed for the bottom blue circle. Thanks everyone.
GasSavers_maxpowers is offline   Reply With Quote
Old 01-27-2009, 05:23 PM   #2
GasSavers_Erik's Avatar
I think the hoses marked with red are correct- fuel pressure regulators need manifold vacuum.
Do you have a vacuum hose diagram on the underside of the hood? What year is this hf?
Old 01-27-2009, 06:26 PM   #3
GasSavers_TomO's Avatar
Looks like you have an OBD1 motor swapped in there. I'm assuming a D15Z1 (VX) motor here:
The right side green circle in the fist picture goes to a solenoid that puts a vacuum on the purge canister for the evaporative gas recirculating system (the gas fume recirculator)
^#11 In that picture
The left green circle in the upper most picture goes to the "Black Box" (EGR Control)
The Vacuum hose goes from the green circled nipple on the left in your picture to #13 and then #14 runs to the EGR vacuum port (middle right blue circle in your pics)
your red circled picture is correct, but shorten the hose as much as you can to remove any vacuum delay on the FPR (Fuel pressure regulator)
Honda Civic VX Info/Links
Old 01-27-2009, 06:55 PM   #4
The HF is a '91 with a d15z1 swap. My hood does have the vacuum routing diagram but the thing is my vacuum control box is uncovered and the lines aren either disconnected or aren't connected well.
Old 01-27-2009, 06:56 PM   #5
Wow...Tom thanks alot. That's exactly what I was looking for.
Old 01-27-2009, 09:28 PM   #6
no prob!
More metric unit options bem Fuelly Web Support and Community News 1 04-23-2011 12:25 PM
Per Month tracking? mauirixxx Fuelly Web Support and Community News 4 12-08-2008 02:04 AM
Nova "Car of the Future" on PBS striegel General Fuel Topics 8 04-24-2008 10:25 AM
Any Toronto Peeps here? bbgobie General Discussion (Off-Topic) 0 06-15-2007 09:11 AM
