Myth? Lean mixtures will cause engine damage - Page 3 - Fuelly Forums
Old 08-09-2008, 07:16 PM   #21
DRW
Originally Posted by Pete View Post
Wouldn't the ratio of oxygen to nitrogen remain the same regardless of the volume?
The "Lean" aspect applies to the volume of air relative to the volume of fuel so although the volume of air is decreased the actual mixture of the air does not alter.
Cheers , Pete.
That's true before the mixture burns. Once ignited only the oxygen combines with the fuel to produce combustion. If there's left over O2 in during combustion (eg lean mixture) it will try to latch onto other molecules, such as nitrogen.
Dave W.
Old 08-10-2008, 03:40 AM   #22
GasSavers_Erik's Avatar
That makes sense DRW, it also explains how EGR helps reduce NOX emissions (less free oxygen in exhaust to react with nitrogen).
I suppose running ultra lean WILL increase NOX emissions.
Old 08-10-2008, 03:58 AM   #23
Hmm...so there's all this nitrogen reacting with oxygen...I wonder if there's a way to persuade it to make N2O and separate it out from the rest of the exhaust, then feed it back into the intake.
Old 08-10-2008, 05:47 AM   #24
GasSavers_bobski's Avatar
I don't know about separating it, but that's more or less what EGR systems do. They mix some exhaust into the intake stream, which replaces some oxygen-rich air in the cylinder. Less oxygen in the mix means reduced NOx emissions.
Old 08-10-2008, 06:07 AM   #25
Yeah, but that's NOx, not N2O...
Old 08-10-2008, 08:34 AM   #26
Actually, that isn't how EGR works. EGR works because the extra inert gasses in the chamber absorb energy from combustion and the combustion is cooler because of that(also gives more to expand from heat of combustion). Additionally, the extra gasses take up space in the manifold and reduce vacuum a lot like our WAI are doing.
The actual oxygen/fuel ratio never changes with EGR. All stock EGR cars still run 14.7:1 on freeway cruise which is where EGR is active.
- Kyle
Old 08-10-2008, 01:50 PM   #27
Originally Posted by dkjones96 View Post
Engines always run their best right before they die.
Yup, thats what he kept saying...
Old 08-10-2008, 04:29 PM   #28
so why not compensate the lean with hho??
I'm leaning out my mixture with map enhancement, o2 enhancement, and wai
2001 Chevy S10 2.2 5 spd man
85,000 Miles
28-34 MPG with HHO
GasSavers_Ven is offline   Reply With Quote
Old 08-10-2008, 04:40 PM   #29
HHO won't help. It's a stoich mixture.
- Kyle
Old 08-10-2008, 09:05 PM   #30
[...] Additionally, the extra gasses take up space in the manifold and reduce vacuum a lot like our WAI are doing.
Uh... What? Warm air intakes work because they reduce the density of the air being pulled into the engine. Lower density means there's less oxygen (and nitrogen for that matter) per volume of air, so less fuel needs to be injected to reach a stoichiometric ratio. Manifold vacuum is unaffected by the temperature of the air.
No, the volume of air/fuel mixture being pulled into the cylinder during each intake stroke is reduced. The mixture is diluted by the exhaust gasses. Less air and fuel being burned means less heat released in the cylinder, lower combustion temperature and therefor reduced NOx emissions.
