My VX idle bounces when rolling in neutral - Page 3 - Fuelly Forums
Old 10-29-2008, 07:08 PM   #21
Originally Posted by Danronian View Post
I had idle problems with my first VX motor (had 238k on it) and I found it was a sticking throttle body that needed to be lubed and cleaned. I also found the throttle cable was adjusted wrong. To me it sounds like it is either a vacuum leak or the throttle body/throttle cable sticking.
yea age and carbon build up will do those things to any car, clean it out (run some seafoam thru the gastank) or open the throttle and scrub with soem seafoam on a toothbrush or somehting.
Autotrans coasting to stop VNelson Hypermiling 13 12-25-2007 09:05 PM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 08:48 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 07:27 AM
Scangauge gets website upgrade ketel0ne General Fuel Topics 1 08-10-2006 05:52 PM
