zpiloto -
Originally Posted by zpiloto
There was a guy that did testing with this I think it might have been the Hydrogen Boost guy. He took a 1/4" copper tubing and wrapped it around the exhaust. His magic number was 220 degrees before he had drivability issues and vapor lock.
You're right that he did experiments, but I can't find specific references on his website. From what I know, using the exhaust worked for him, but he didn't consider it viable for a long term installation because it was vulnerable to breaking and leaking fuel
Most aftermarket heater use the radiator hose for heating which I think is to keep the temerature around 190 degress which is probably the number you want to shoot for. It does recirculate the fuel so you will be warming the tank.
On my 626 I used 3/8" copper tubing across the radiator wrapped in foil and saw a 3% increase. Might do a search this has been covered before. There was some problem with using cooper because of the way gasoline reacts with it over time. All in all it kind of a risky proposition and I won't be doing it on my current ride because the risk don't exceed the gain IMO. The fire bottle on the passenger floor is all ways a good converstaion piece though.
Looking at your garage You best best might be to finish off th aero mods. With as much highway traveling that you do aero is going to give you the best bang for the buck after driving techniques.
My hydrogen-boost comes with a fuel heater that uses the radiator coolant :
It's basically just a spiral of copper pipe that you run the radiator hose through. The fuel goes into the spiral of copper tubing (one of the little "antenna" in the picture), is warmed up by the hot radiator hose, and comes out the other end (the other "antenna"). I would guess that the number of spirals would control the average temperature increase of the fuel.
My mechanic won't install it because he fears that it can't take the fuel PSI, but I think he is being smart (protecting himself from liability).
Artic fox makes fuel heaters for Diesel fuel, but I think that some of them can be adapted for gasoline :
Biodiesel Fuel Warmers & Accessories
http://www.arctic-fox.com/sitepages/pid74.php
I think in all cases it comes down to controlling the maximum temperature increase of the fuel (vapor lock?), right?
