my catalytic converter - Fuelly Forums
Old 10-05-2009, 02:07 PM   #1
Angry my catalytic converter
my car wastes alot of oil and i lose power when im in a hill ....i took it for a check up and they told me it was my catalytic converter its like 1300 to fix thats to much right what else can i do ...plus my engine light goes and comes every other week...i need help please
jose2002 is offline   Reply With Quote
Old 10-05-2009, 02:12 PM   #2
They are full of crap. Oil consumption has absolutely nothing to do with the catalytic converter.
Oil consumption can kill a cat and muck it up causing your power loss but if you don't fix the reason for consumption you'll be right back there getting it replaced again.
- Kyle
Old 10-05-2009, 04:12 PM   #3
imzjustplayin's Avatar
agreed
Old 10-05-2009, 06:25 PM   #4
You need to hook up a code reader to the car to see what code it is setting when the check engine light comes on. The light doesn't have to be on when you check the codes. The code will be stored in the ECU for a certain number of starts after the light goes out. The problem may or may not be related to the catalytic converter.
Hipermiler
#47 on my way to #1
Old 10-10-2009, 07:54 AM   #5
kamesama980's Avatar
What is the car? that'll make a difference in how to fix it.
I've heard of cleaning a cat by disconnecting a spark plug and letting fuel through the cylinder. it'll hit the cat and burn there instead causing a lot of heat buildup that can burn off carbon from the oil consumption. the problem is if you do it too long you can melt the cat and then you REALLY need a new one.
-Russell
Old 10-10-2009, 08:43 AM   #6
hmm well theres no easy way to fix burning oil. somethings worn out seal wise or the rings are stuck.
what kinda car we talkin about here?
Pulse and Glide with the engine running? neverendz Hypermiling 17 12-27-2008 09:25 PM
what is a good moped/scooter to look for? meangreen Motorcycles 26 12-12-2008 06:27 AM
600 Mile Round Trip Ford Man General Fuel Topics 3 10-27-2008 06:33 PM
Am I crazy for thinking like this? imzjustplayin General Discussion (Off-Topic) 24 10-19-2008 08:53 PM
'93 Chevy 2500 4x4 + Trailer: Help! rh77 General Fuel Topics 9 09-15-2007 09:31 AM
