Metro 3-cyl General Info - Page 4 - Fuelly Forums
Old 07-11-2006, 11:55 AM   #31
Displacement x RPMmax /2 = CFPM (make sure you get the CC/Cubic Inches right) then calculate the fuel needed for that air flow rate to obtain the fuel flow rate at the air/fuel mixture ratio. Or figure the rate you could burn fuel at at max speed with maybe 45mpg at 90mph = 2 gph then convert the units to cc/minute.
Old 07-11-2006, 12:41 PM   #32
95metro's Avatar
Okay, great help from http://www.docinjector.com/
Not much on their site or their eBay store, but I emailed them and they responded really quickly.
Apparently the injector size is a huge 400 cc/min (39 lb/hr)! I guess it makes sense considering that it is one injector feeding three cylinders = 133.33 cc/min/cylinder (13 lb/hr/cyl).
95metro is offline   Reply With Quote
Old 07-11-2006, 06:05 PM   #33
Oh Yeah it is a throttle body injector in the Geo - maybe a turbonator would work and acetone too!
I guess to figure out the CC of gasoline you need the weight or volume of air to gas ratio I guess it is by weight 14 to 1 ratio?
Old 07-13-2006, 09:35 AM   #34
So are you going to shift to the GM Sychromesh fluid? I can somewhat relate to the question about using gear oil in the Swift. If Honda has me putting in engine oil, I would think the Swift would definitely need a similar viscosity.
Old 07-13-2006, 09:39 AM   #35
95metro's Avatar
Actually I'm considering 0W20 since the winters are so cold around here. krousdb doesn't seem to be having any trouble with it in his Honda's and I'm running a Japanese drivetrain as well...
Currency Support Stonewolf Fuelly Web Support and Community News 2 08-23-2008 02:18 AM
p07 ECU $15 Matt Timion For Sale 4 08-27-2006 11:25 AM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 03:22 PM
Some glue that won't melt when it gets hot? SVOboy General Maintenance and Repair 16 08-01-2006 07:15 AM
