I thought they all had hydraulic lifters.
Mechanical lifters are the norm on Hondas these days. I was surprised that my first Civic required valve adjustment -- never heard of such a thing. After they seat, they recommend adjustment if they become "noisy", per the manual, on the newer models.
As far as IATs go, I've been running relatively stock air of between 50-100F, so detonation probably isn't an issue.
After the car came back from the body shop, the PCV catch valve was upside-down (they probably messed with it -- darnit), so all that gunk was sucked back into the engine. Perhaps time for Seafoam or Auto-Rx?
I did a full-RPM run-up today to see if there were any misses or abnormalities, and the only thing I noticed was a big increase in power. It really took off. Then again, I haven't really "ran-it" for a few months for FE.
...and FE is up.
Timing advance may be a issue to consider. I'll take a look at the SG's timing numbers tomorrow (if that will show anything). Since the stereo's not working right now, I can really hear the engine all the time during my commute. Climbing a hill sounds like an old Mercedes Diesel (no smoke, thank goodness).
Anyways, I'll add valve adjustment to the list of maintenance items
