Lifespan of a thermostat - Fuelly Forums
Old 07-30-2012, 11:56 AM   #1
Planning to do coolant flush soon. Should be the first time for this car. There is some recommendation on the HHR boards to go ahead replace the thermostat while the flush is done. It would be an excuse to try a warmer thermostat, but I don't see the point if the old one isn't broke and has plenty of life left.
What are the opinions here?
Old 07-30-2012, 01:52 PM   #2
Re: Lifespan of a thermostat
2 things...
1)you cannot properly flush the system w/out removing it
2)always(every time) replace it if you flush, replace hoses, install radiator, etc
very cheap maintenance...it would be a waste to do any coolant service then have to go back and drain and refill again!
190 or 195*F could yield better economy
Old 07-30-2012, 07:43 PM   #3
Thermostats are cheap, if you have it apart anyway, just replace it.
Old 08-01-2012, 01:07 PM   #4
a thermostat is 10 bucks... JUST REPLACE IT.
civic94 is offline   Reply With Quote
Old 08-01-2012, 07:02 PM   #5
GasSavers_WD40's Avatar
I would have had to pay over $80 for the proper 192 F thermostat at the Honda dealer up here in Canada.. they gave it to me because they had to order it in and it was late getting in.
I'm sure the girl that gave it to me was in trouble after that, but hey ..customer service was nice from a dealer for a change.
GasSavers_WD40 is offline   Reply With Quote
Old 08-02-2012, 10:10 AM   #6
It was $21 here. No luck finding a higher temp one though. Stuck at 180F.
Old 08-02-2012, 10:15 AM   #7
I'd say if 180 is what the manufacturer recommends, that's what I'd put back in. If you raise it to a 195 the computer may start richening up the mix or playing with the timing to try and cool it back down.
Old 08-05-2012, 06:03 PM   #8
add|ct's Avatar
^I agree here.
'92 Civic VX, Canadian model
2012 Prius question VX_Arky General Fuel Topics 4 08-01-2011 06:10 AM
suggestion: running averages of data? roadent Fuelly Web Support and Community News 4 10-27-2008 10:58 AM
new to the site ranger387 Introduce Yourself - New member Welcome 5 11-12-2007 07:17 PM
another new guy jbrando Introduce Yourself - New member Welcome 4 07-10-2007 09:51 PM
Gaslog suggestion SVOboy General Discussion (Off-Topic) 1 04-29-2006 09:35 AM
