Kill switch questions - Page 2 - Fuelly Forums
Old 06-27-2008, 09:16 AM   #11
Just googled auto shut down relay. Interesting, I've never heard of it. How does one begin looking for its location?
Old 06-27-2008, 09:40 AM   #12
If you've got a relay block or box under the hood that's labelled, it might be in there. Otherwise check the Haynes/Chilton manual, EBSCO auto repair guide at local library or the repair guides at www.autozone.com
Old 06-27-2008, 09:45 AM   #13
Actually, you probably wanna forget about the ASD unless you have a chrysler or jeep..... but just tripping out the crank sensor signal would probably work for a kill switch.... http://209.85.215.104/search?q=cache...ient=firefox-a
Old 06-27-2008, 09:57 AM   #14
I suspect that killing at the crank sensor will definitely throw a code.
Old 06-27-2008, 11:12 AM   #15
GasSavers_bobski's Avatar
Yep. That's really the problem with most of the easy approaches to killing the engine. The ECU (ECM, whatever) is designed to keep the engine running, so it complains when you interfere with it.
Maybe interrupt the ignition on signal to the main relay? That would cut power to both the ECU and fuel pump. The distributor portion of the ignition system would still be getting power, but the ECU wouldn't be able to tell it to fire. A few solenoid valves get power directly from the ignition switch and ground through the ECU, but as far as I know, that shouldn't be a problem.
Criteria for getting and staying on the overall histogram Codyroo Fuelly Web Support and Community News 1 07-06-2012 04:58 AM
Allow Us to Email to Fuelly Our Updates? TNTDJ Fuelly Web Support and Community News 1 01-04-2011 12:13 PM
Question on fuel cutoff during coast Rick Rae General Fuel Topics 3 08-20-2007 07:19 PM
Regenerative braking??? 80cvcc General Fuel Topics 5 07-19-2007 10:06 AM
1988 CRX DX (the Bantam) GasSavers_Jack For Sale 6 09-08-2006 04:59 PM
