Just installed my new NTK 5 wire o2 sensor. - Fuelly Forums
Old 05-29-2008, 08:21 PM   #1
92VXHatchguy's Avatar
Smile Just installed my new NTK 5 wire o2 sensor.
Won this from ebay for $95 brand new. So far, no check engine light. I bought the o2 sensor socket from Harbor freight for 3.99, removed the old one, and screwed in the new one. Maybe it's me, but it seems like it runs a little better. I'm getting major service done tomorrow, so hopefully everything will be running in tip top shape. I'm hoping it will pass smog, so I can finally get the title in my name.
Has anyone hear tried to clean out their old o2 sensor? I'm wondering if these can be salvaged by cleaning out the dirt and crap that has been building up for the last 16 years. I'm not sure if this part has ever been changed from the original owner.
Former VX Owner
DD is a 1993 Civic Si Hatchback
92VXHatchguy is offline   Reply With Quote
Old 05-29-2008, 08:25 PM   #2
Haven't tried cleaning mine yet, but it would seem like filmless cleaners like carb cleaner would be best so it would not leave a residue for anything to buildup on other than normal soot. Mine looks newer, wires are very clean compared to the rest of the underhood harnesses and connectors. I'm replacing my cracked manifold and cat with a Hedman header, and will have to extend my O2 wires if its in a different location. Repost how your smog went, I'm in the same boat trying to register the car that failed smog as you.
jshelton441 is offline   Reply With Quote
Old 05-29-2008, 08:29 PM   #3
I'll definitely post up what my readings are. I don't have the old readings because I bought the car w/o it being smogged. The prior owner didn't have anything except a carfax and the pink slip. I'm happy with the car. I'm finally getting things done little by little.
Former VX Owner
Old 06-04-2008, 03:07 PM   #4
I haven't done it, but I've read about folks using a torch to clean it. Or to try to clean it.
On youtube there's a fun video of someone using a torch to test two VX O2 sensors. If you're a VX geek like me you'll enjoy watching it.
http://www.youtube.com/watch?v=iXPdhai_5iE
Old 08-27-2008, 11:06 AM   #5
slogfilet's Avatar
any tips/experiences on cleaning or refurbishing an old o2 sensor?
slogfilet is offline   Reply With Quote
Old 08-27-2008, 01:05 PM   #6
If you're trying to pass smog the O2 is only a very small portion of the big picture. I could go on for days about all the factors to consider and look into. Biggest thing I can suggest though is running a fairly high % of alcohol/ethanol. This will bring combustion temps WAY down reducing NOx, and generally burns a bit cleaner, giving you more flexability in fuel ratio.
If you're running super rich or lean you'll still fail though. EGR function is also important, test to see if it's working.
GasSavers_Gollum is offline   Reply With Quote
Old 08-27-2008, 02:26 PM   #7
(Quote) Has anyone hear tried to clean out their old o2 sensor? I'm wondering if these can be salvaged by cleaning out the dirt and crap that has been building up for the last 16 years. I'm not sure if this part has ever been changed from the original owner.[/QUOTE]
I've never tried cleaning one, but a friend of mine that does mechanical work for a living told me a few years ago that you could clean them with Sea Foam. He said just put a little bit in a container just enough to cover the sensor and let is soak over night. Try it at your own risk, but if you already have a new one what have you got to loose?
Hipermiler
#47 on my way to #1
Old 08-27-2008, 02:33 PM   #8
(Quote) I'm hoping it will pass smog, so I can finally get the title in my name.
Auto Zone sell a product called Berryman Emissions Pass Protection that is guaranteed to make your car pass emissions testing as long as you don't have any bad emissions parts.
Hipermiler
#47 on my way to #1
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Cruise Control in Civic McPatrick General Maintenance and Repair 16 07-13-2007 03:20 PM
New Japanese Crap Request Thread SVOboy General Discussion (Off-Topic) 10 07-01-2007 03:34 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
