It didn't just do it once, but no it had to do another one. (RANT) - Fuelly Forums
Old 04-01-2006, 12:12 PM   #1
Compaq888's Avatar
ago there was a power steering leak. One of the hoses got loose. So I tightened the hose back up. Problem solved. Today I was changing the oil and saw a good amount of red fluid. I looked around and the inner tie rod boot was ripped. The really bad
Like a month ago there was a power steering leak. One of the hoses got loose. So I tightened the hose back up. Problem solved. Today I was changing the oil and saw a good amount of red fluid. I looked around and the inner tie rod boot was ripped. The really bad part is you have to take so much apart just to replace it. Dealer wanted $300 just for the work. The part is like $12.
Dealer suggested if I don't want to fix it I should just keep adding fluid. Fluid is cheap, it's 2.74 per bottle. The rip is not that bad. But it could get worse!!
Old 04-01-2006, 03:16 PM   #2
|V3|2D
thisisntjared's Avatar
that sucks. how did it
that sucks. how did it tear? years of auto x use? or just age?
it shouldnt be that hard to do yourself.... i mean im no nissan expert but with hondas its pretty easy...
Old 04-02-2006, 09:43 AM   #3
Compaq888's Avatar
It's nissan, anything rubber
It's nissan, anything rubber sucks on it. There are a lot of rubber stuff ripped on it, but this rubber is more important because it's a boot.
More SMS Requests zbret Fuelly Web Support and Community News 16 02-03-2011 01:09 AM
What mods/fixes are you planning? 95metro General Fuel Topics 45 05-25-2006 02:26 PM
Digital Speedometer Matt Timion General Discussion (Off-Topic) 11 01-05-2006 05:48 PM
