is this a d15z1?? (JDM d15b) - Fuelly Forums
Old 11-29-2007, 08:35 PM   #1
just got this in the mail today (yipee!)...but I hesitated when I saw this on the block:
"HM
D15B
7603434
1
95"
I was told that this was one of those JDM imported engines and was a d15z1...just wanting confirmation that this is the real deal!
Here's a pics of the engine (it looks to be the correct valve cover and exhaust manifold...so I'm assuming it's the d15z1)
from post #4 in (http://www.gassavers.org/showthread.php?t=5770) :
Originally Posted by Matt Timion View Post
once again, there are three JDM d15b engines.
There is one that is the EXACT same as the d15z1
There is one that is a normal Vtec engine like the d16z6
and there is one that is the is three-stage vtec engine, offering the best of both worlds.
thanks for any help!!
first350 is offline   Reply With Quote
Old 11-29-2007, 09:12 PM   #2
Danronian's Avatar
Looks like it from this pic.
Take a pic of the vtec solenoid (near the EGR valve mounted to the head). If it only has one solenoid, it's vtec-e. Also checking to see if it has roller rockers will tell you if it's the vtec-e instead of the vtec motor.
Old 11-29-2007, 10:45 PM   #3
thanks for the help!!!
I think this is the solenoid, right? (looks like there's only 1)
here's another shot w/ the intake manifold removed (what I beleive to be the solenoid is on the right side):
Old 11-30-2007, 06:24 AM   #4
GasSavers_TomO's Avatar
I can't see the pics at work, but look all around on the head and see if there is a P07 stamped or marked anywhere on there.
Honda Civic VX Info/Links
Old 11-30-2007, 07:22 AM   #5
GasSavers_bobski's Avatar
Yes, that's the VTEC solenoid, but the statement earlier about VTEC and VTEC-E motors having a different number of solenoids is incorrect. Performance VTEC motors also have only one solenoid. To my knowledge, the only D-series motor with two solenoids is the two-stage VTEC D15B.
On the other hand, those intake ports look too small to be a performance-VTEC motor, so it probably is in fact a VTEC-E design.
Another thing I notice from those pics is that it appears someone has screwed a bolt in where the VTEC pressure switch should be. Maybe VTEC-E motors don't use one? Can a VX owner chime in?
Old 11-30-2007, 09:18 AM   #6
Danronian's Avatar
I was trying to make sure it wasn't the two-stage model. Thanks for the input.
It sure does appear to be a vtec-e motor.
Old 11-30-2007, 09:52 AM   #7
thanks guys...everything I've seen appears to point to a d15z1 engine, except for the "D15B" on the block itself...hopefully that's just the JDM-->USDM difference.
I should have the head off this Saturday, so hopefully that'll verify that it's a d15z1.
Old 11-30-2007, 10:20 AM   #8
Matt Timion's Avatar
that's the d15z1... Japan just called it D15B, along with two other engines. the dead give aways are the "VTEC-E" on the top, as well as the smaller intake manifolid.
Old 11-30-2007, 10:25 AM   #9
Danronian's Avatar
Taking the head off?
Are you rebuilding the motor? Or are you just doing it to replace the headgasket?
Old 11-30-2007, 10:34 AM   #10
GasSavers_Ryland's Avatar
your throttle body intake looks a little bigger then I would have exspected, my vtec-e throttle body is around 2" where the flexable rubber connects to it.
most of the magic of the vtec is found under the valve cover, the 2nd set of valves ride on a rounder, insted of egg shaped lobe most of the time, then move a pin to lock it to the part of the rocker arm that is riding on a regular lobe to alow it to open the valve more, the higher performance vtec engines have all the valves ridding on regular looking lobes, and have an extra lobe that is even more aggressive for when you hit really high RPM, so if you take the valve cover off and a photo of the top side of the head then you can tell for sure.
Is there an ez way to get back to the dashboard? johnblue Fuelly Web Support and Community News 1 12-11-2011 12:41 PM
I'm Alive! trebuchet03 General Fuel Topics 10 08-14-2007 08:53 PM
cuts in my rear bumper thisisntjared Aerodynamics 13 07-04-2006 04:50 PM
What is your favorite bulletin board software? Matt Timion General Discussion (Off-Topic) 5 03-30-2006 05:43 PM
airflow - is more or less better? Matt Timion General Fuel Topics 14 10-01-2005 02:57 PM
