Is my wife's clutch going out? - Fuelly Forums
Old 03-31-2006, 04:49 PM   #1
Matt Timion's Avatar
e timing is laughable, as I was just planning the transmission swap (assuming I can get the damn thing off tomorrow, and that there is no rain). here are the symptoms: When I drive (in any gear) the car revs to 3000rpms, and then drops down to th
of course the timing is laughable, as I was just planning the transmission swap (assuming I can get the damn thing off tomorrow, and that there is no rain).
here are the symptoms: When I drive (in any gear) the car revs to 3000rpms, and then drops down to the correct RPM where the car drives. IOW, the RPMs go high and then go down at which point the car starts to move.
Old 03-31-2006, 06:45 PM   #2
philmcneal's Avatar
did you try the 5th gear
did you try the 5th gear challenge? Try to start the car in 5th gear and the call should stall even if you bring the revs up. If it doesn't and the revs slip a lot then its time for a new clutch.
Old 03-31-2006, 08:46 PM   #3
Re: Is my wife's clutch going out?
Well, how many miles, and how did the 5th gear challenge work? It could be the the clutch (most likely) or the manual transmission fluid. Does the pedal act differently (like go further to the floor to engage a shift, and/or is it hard to shift?)
Old 03-31-2006, 09:52 PM   #4
I'm going to have to try the fifth gear challenge tomorrow. It quit doing it, so I'm wondering if it's a fluke.
Needless to say, if i swap transmissions I will be installing a new clutch while I'm in there. It would be stupid not to.
Average running mileage on dashboard mistakely same as last fill-up. MatrixDom Fuelly Web Support and Community News 3 06-15-2011 03:21 AM
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 01:14 AM
SMS fuelup went to wrong car todd Fuelly Web Support and Community News 4 03-17-2010 03:31 AM
how's your MPG compared to others with the same car? MetroMPG General Fuel Topics 21 02-20-2009 03:37 PM
Kansas City GasSavers_katman General Discussion (Off-Topic) 1 05-27-2006 10:01 AM
