Used the original grommet in the firewall from the cable VSS to run the electronic VSS wires, 3 total, power, signal and ground. Ground went to the dashboard frame, power I spliced into one of the power lines already going to the cluster and the signal I split into two and ran one to the cluster and one to the original VSS line that ran to the ECU.
Wire-loomed the wires and taped it all up good.
Here is how it sits now. I did the install without cutting off either of the mounting tabs on the Integra cluster. I managed to wedge it in there really tight and ended up using good ol' zip-ties for added security.
All in all it wasn't too bad of a project. I have almost no experience with wiring hence why I wanted to either keep the CRX plugs in there or make it easy to revert back to it if need be.
I recommend this to anyone who thinks that they can do it. Just be sure to read up a lot on it beforehand.
